TC30 won't crank over
   / TC30 won't crank over #1
reholt
Everson, WA
2003 New Holland TC30
I am having problems getting my TC30 to start...yeah it won't. Glow plugs work, lights illuminate, etc., but won't turn over when I turn the key. Confirmed that tractor is in neutral, park brake set. I checked the seat safety switch by using a jumper wire to bypass the seat switch and it still doesn't turn over. What should I check next? Thanks for your help! :confused:
   / TC30 won't crank over #2
Use a test light to make sure that power is going to the starter. Should be the pink wire if I remember correctly.
   / TC30 won't crank over #3
I replaced an ignition switch 3 years ago...
Check your battery...
I replaced mine 2 years ago and it was deader than a hammer last month...
It had an 18 month replacement warranty on a commercial battery...
I replaced it with a Wal Mart 84 month warranty battery...
I was surprised that it went out so fast...
   / TC30 won't crank over #5
Before you go tossing parts at it, test to see if you have power to the starter like I said and work your way back from there. Electrical issues aren't tough to diagnose...you just need to have a plan for it. Tossin gpart at it is fine if you've got deep pockets......I don't though. lol
   / TC30 won't crank over #6
some safety switch acting up maybe (PTO, seat etc.)
Thanks to all who replied! I really feel stupid...I found that somehow the PTO lever had been engaged...thus no crank when I turned the key.:confused2: Once I disengaged the PTO lever, "Ole Blue" fired off just like always! Thanks again to the helpful community here on TBN!
   / TC30 won't crank over #8
I've done dumber lol
Always nice to hear when a fix is free and easy.
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
Kubota BX25D (A53317)
2007 Heil Heavy Duty Aluminum Tank Trailer (A56438)
2007 Heil Heavy...
2001 CATERPILLAR 140H VHP MOTORGRADER (A59823)
2001 CATERPILLAR...
Hutchinson 30' Unloading Auger (A59814)
Hutchinson 30'...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
