TC30 won't crank over
   / TC30 won't crank over #1
reholt
Everson, WA
2003 New Holland TC30
I am having problems getting my TC30 to start...yeah it won't. Glow plugs work, lights illuminate, etc., but won't turn over when I turn the key. Confirmed that tractor is in neutral, park brake set. I checked the seat safety switch by using a jumper wire to bypass the seat switch and it still doesn't turn over. What should I check next? Thanks for your help! :confused:
   / TC30 won't crank over #2
Use a test light to make sure that power is going to the starter. Should be the pink wire if I remember correctly.
   / TC30 won't crank over #3
I replaced an ignition switch 3 years ago...
Check your battery...
I replaced mine 2 years ago and it was deader than a hammer last month...
It had an 18 month replacement warranty on a commercial battery...
I replaced it with a Wal Mart 84 month warranty battery...
I was surprised that it went out so fast...
   / TC30 won't crank over #5
Before you go tossing parts at it, test to see if you have power to the starter like I said and work your way back from there. Electrical issues aren't tough to diagnose...you just need to have a plan for it. Tossin gpart at it is fine if you've got deep pockets......I don't though. lol
   / TC30 won't crank over #6
some safety switch acting up maybe (PTO, seat etc.)
Thanks to all who replied! I really feel stupid...I found that somehow the PTO lever had been engaged...thus no crank when I turned the key.:confused2: Once I disengaged the PTO lever, "Ole Blue" fired off just like always! Thanks again to the helpful community here on TBN!
   / TC30 won't crank over #8
I've done dumber lol
Always nice to hear when a fix is free and easy.
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
Unused 2025 GIYI KH72 72in 4-Way Hydraulic Bucket Skid Steer Attachment (A51691)
Unused 2025 GIYI...
2022 BOBCAT T66 R-SERIES SKID STEER (A51246)
2022 BOBCAT T66...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
1987 Ford F800 Fire Truck (A51692)
1987 Ford F800...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
