BX LED worklight upgrade
/ BX LED worklight upgrade #1
Scooby074
Super Member
Nova Scotia
BX 25, ZD 326
I just (well a few days ago) installed an LED worklight that's been sitting on my shelf for about a year on my BX and thought I'd share my install. The Light is a Lucidity 22809B. Its a 6LED 1000 lumen fixture. The light it adds to the BX's feeble headlights is amazing. Ill try to get some night shots to show the difference, but suffice it to say the LED is brighter than the factory headlights, maybe 2x as bright? After my first use at night I was so impressed that I called Princess Auto to look for another one of the lights... Unfortunately it was a "special buy" and if you know PA, you know what that means, "They dont know if they're ever getting any more in" ... needless to say Im ticked. I'd buy another in a second! Incase anyone wants to check out their local PA, the SKU 8412140 , Price $49.99 4 x 4 in. Utility LED Flood Light | Princess Auto
Light Specs:
Onto the install, sorry no in progress pics, but I will answer questions:
The mount is a basic T. The arm of the T is 1" angle, and the top is 1"x1/4" flatbar. On the ROPS side of the top of the T, I glued some rubber to act as a vibration isolator and to prevent the light from sliding down. Bolts are 1/4" stainless 2.5" long. Paint is Plastikote 285 Rebuilders Cast. its very close to Kubota ROPS gray paint.
From the rear
Bored the centre mounting bolt out to pass the light's wires
I used rare earth magnets to hold the light to the arm. This allows me to swing the light to the rear for snowblowing etc. Notice the mounting bolt's locknut is loose to I have clearance to pick the light up to turn it
/ BX LED worklight upgrade #2
Nice work, it looks good. I just bought a 3 lights kit from Bxpanded, but it won't be here until Friday. I feel like a kid waiting for my new toys.
/ BX LED worklight upgrade #4
Scooby... just looked it up...
their website says it's available for on-line ordering.
doesn't seem to be any way to check stock at stores though.
Pete
Pete
Thanks for noticing that! I swear it was unavailable when I posted the link.
Just called Winnipeg. They have 20 in stock at the head warehouse. But even better news, apparently this light is coming on promotion this tuesday. For $49.99. At all stores. I think he said that Halifax has 20 in transit.
Just goes to show you that sometimes you get an idiot at the store (which is a surprise, usually PA's staff is decent). He swore up and down that they were not getting any more in.. I even had him check the computer for stock and he said there was none ANYWHERE nor would there likely be any more in the future!
Im going to put one away at $49.99 for pickup next time im near the store. If anyone else is interested in a LED workight, and theyre in Canada, I highly recommend one of these, especially at the price. It's very bright, and seems to be solidly made. The only thing Im debating is whether to buy 2 more, both for the LH side, one permanently forward and one permanently rear.
/ BX LED worklight upgrade #6
That's pretty clever! :thumbsup:
You'll notice a HUGE improvement. The factory lights on a BX suck. The Bxpanded kit is nice for an out of the box solution.
The mounts look good.
Thanks. Hardest part was trying to match the ROPS colour without going to the dealer:D
Thanks. Rare earth magnets, is there anything they cant do ;)
In all honesty though, if I knew then, what I know now (that the lights are going to be available again) I'd probably have just bought 2 more lights and not bothered with the fancy mount, although it works excellent.
/ BX LED worklight upgrade #9
I just picked up 2 of these lights after seeing your posting. They were $50 @ princess auto. They only had 3 in stock @ the Whitby store. (1 now). They look to be of good quality. Nice large aluminum heatsink. Waterproof.
I have them mounted on my rops. Just have to finish wiring.
I got one myself. I have it on the LH side forward facing, permanent mount. I would have added a permanent rear facing one, but there was none left. 50 lights sold out in one day!! I did make the mount large enough and drill a whole to add a rear one when they bring these lights back in stock.
As the factory feed to the rear work lights is unswitched and not tied into the head light circuit, I had to add a switch to control the lights. (id look pretty stupid mowing the lawn in broad daylight with the work lights on ;))
Not too hard a job. Just cut the red/black line at the fusebox and splice in a short loop to the switch. The switch I used was a genuine Carling Contura switches. They are marine grade and have a great reputation. V-Series: Contura II & III | carlingtech.com I was hoping to get the ones that allow you to put the inserts into it to indicate the function, like this 1329149362659173.jpg, but they didnt have them. I can always retrofit one later when I find it.
So here's the pics:
Splice at fuse panel. Splice wire is inside the small loom cabletied to the larger bundle :
Contura switch mounted. This was about the only flat real estate I could find on the dash:
Right and left light's mounted, facing forward:
/ BX LED worklight upgrade #12
We need some pictures of them in action.
/ BX LED worklight upgrade #13
Nice Job Jason. I know first hand just how effective L.E.D. lights can be. Well done :thumbsup:
Will do!
Thanks.
Its hard to beat LED's for sure. I just found a local source for Rigid LED's too!! Thankfully I already had the (much cheaper) lucidity's from PA, otherwise Id have a $250 set of Duallys hanging off the BX.:D Apparently they Rigids are selling in large numbers here which is impressive considering the price and that they were just added to the lineup this fall. Im really considering a set for driving lites on the truck.
Your running Rigids on your Kubota arent you?
/ BX LED worklight upgrade #15
I got a mix of everything on mine. There's Whelen, Grote and Rigids. All great lighting and all crazy expensive but when I open the shop door and head out in the storm I'm confident in the lighting. I'd like to put a set on our van but there's nowhere to place them. To many moose of our highways and to many dying because of them.
+1. My brother is in NFLD. Driving is like Russian Roulette with the number of moose over there.
/ BX LED worklight upgrade #17
Ya it's pretty frightening. I remember seeing a TV show a few years ago and they stated that Newfoundland was one of the most dangerous places on earth to drive due to all the moose :shocked:
An update. So far Im loving the LED worklights. The tractor is actually usable at night! An amazing difference and goes to show how lacking the factory lighting is.
So comparison shots. All taken with no flash , from the drivers seat. Im not sure it will do the improvement justice, but here goes:
Firstly the factory headlights, with the loader at the level I usually carry it at.
Next, LED worklights only. Amazing improvement.
Lastly, LED and headlights combined. Notice that most of the light is from the LEDs
Looking from the ground back at the tractor
Overall, I cant recommend a lighting upgrade enough. It really is embarrassing what lighting Kubota has on these tractors from the factory. Best $150 or so Ive spent in a while.
/ BX LED worklight upgrade #19
LED's sure do make the headlights look yellow.
Yale GLP070VXE 6,500lb Propane Forklift (A61572)
Yale GLP070VXE...
2008 Ford Mustang Convertible Coupe (A61574)
2008 Ford Mustang...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
8' DISC HARROW (A60430)
8' DISC HARROW...
LIGHT PLANT MUSTANG CAT (NONE TITLED) (A63569)
LIGHT PLANT...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
