Snow Attachments Snow chain hitting my frame.
/ Snow chain hitting my frame. #1
woodyacres
SE Michigan
Kioti DK35SE
Hi guys,
I have been on the lamb lately as i have 2.5 year old and havent had much time to browse the site much. But, now i am in need of some help.
Does anyone else have this issue? Am I not doing something right?
I bought these from tirechains.com last year and couldn't get them on before the 30 day return policy. It didn't snow much and I didn't have time. Now, I am trying to use them and they are tearing up my tractor. Any advice would help...
I will add a pic as soon as I can figure out how to add them from my IPad...
Thanks.
/ Snow chain hitting my frame. #2
Are you using are you going to have to use tire spacers to get the wheels away from the frame? Can the chains be tightened to remove the slop ? With all the knowledge out here someone will have a solution for you. Come on with the photo.
I don't have spacers. Thought about it, but not sure where to get them, plus longer bolts.
/ Snow chain hitting my frame. #4
Run bungee straps across the diameter of the outer wheel to pull up the slack. If there's any loose ends flopping around, tie them down with zip ties.
So, is that my issue? The chains just aren't tight enough? I wish I could get the picture uploaded. But, my iPad won't let me.
Ok, I had to get the old laptop out to get the picture uploaded. Here is my dilemma...
My chains are hitting my frame.
/ Snow chain hitting my frame. #8
Well... that's hard for us to know without a look see.
It 'may' just be the slack in the side wall of the chains slapping the tractor as the wheel spins or it could be a clearance issue. Many folks have had to add spacers or... if the the tractor permits and the wheel is capable of being turned... mount them inside out.
We're just giving suggestions based on what it 'could' be. That's about all we can do without photos.
/ Snow chain hitting my frame. #9
that cant be right. There is no room for the chains at all. Is the fender bent or do you have too much air in the tires? What the tire pressure ? Have you tried to let some air out or if they are loaded, Do you know if they are loaded past the 75% space of tire?
/ Snow chain hitting my frame. #10
Thanks for the pic... you posted that as I was typing.
WOW... that is really close clearance between the tire and the brace.
Looks like spacers or swapping the wheels are next.
No amount of chain tightening will eliminate that problem.
/ Snow chain hitting my frame. #11
I could not install chains on my Mahindra 2615HST as it came form the factory. The older models (mines a 2004) only have 1/2" between the frame and tire. Newer ones (2006 and up) have different backspacing on the wheels which move them out enough for chain clearance. Wheels are not able to swap from side to side to get the spacing needed. I had a machine shop make up 2" spacers for my rear wheels and bought the longer bolts at a local fastener store. Haven't bought chains yet but do have a 900 lb. counterweight on the 3 pt. With the snow we got last night (about 16") I sure could have used chains today. Lots of tires spinning without them even with the weight. Guess I'll have to get a set. My wheels are 6 bolt on 6" spacing. Many compact tractors use a similar pattern. I've attached the drawing (supplied by another member) that I supplied to the machine shop.
  • spacer-1.pdf
/ Snow chain hitting my frame. #12
I have the same model DK35 SE tractor with the same problem. My first DUO chains were similar to yours. They came down too far on the tire sidewall and hit the frame. I returned them for a shorter cross chain pattern of 13 chain links and am able to make those work. I had to pound the cross chain hooks flatter to get the required clearance. They still are close to the fender post but they do clear.
If I was doing it again I would get DUO's with 11 or 12 cross chain links so they ride higher on the tire. I may eventually modify my chains by removing 2 links. It would be a lot of work and I would need to add two DUO patterns to each side. I got a quote for those patterns this year at around $40 each I believe. So that would be around $200 with connecting links and taxes, plus a lot of work. I would likely be further ahead buying new chains.
My chains work OK now but if I were doing it again I'd get something like Trygg or Aquiline. Even then there would be a problem if the side chains come too low on the tire. The single piece rim, wide 43x16-20 tires, and very limited clearance are problematic with chains sized to sit 1/2 way down the sidewall. I think my cross chains are around 25 or 26" long. With two less links they would be around 22" I believe.
Wheel spacers would work but would likely be expensive. I wish the DK35 had two piece rims so clearance could be increased that way.
Mine work fine since I flattened the cross chain hooks. I do need to make sure I get the inside side chain above the thickest part of thhe sidewall and pull them tight with bungees.
Thanks, guys. I am going to try and let some air pressure out as I am to factory spec now. If that doesn't work... I guess it's spacers as I am past the point of returning them to tirechains.com. It would be nice if that would be a question they asked before recommending chains for a tractor though.
/ Snow chain hitting my frame. #14
On my Kubota if I had AG tires there would be plenty of room for chains but because I have R4s it uses different rims. I'm running semi truck chains that I shortened and only go 2 links over the edge of the tire.Just have to keep them tight still not much room.
/ Snow chain hitting my frame. #15
I have made spacers out of Lexan (polycarbonate plastic) and they worked fine - You can order the 1/2" 3/4" or 1" thickness from most glass shops.
Well, I let the air out of my tires to 15# and it's still hitting. I guess I am gonna get plates made up this week. A buddy owns a fab shop and said he would make them for me for the price of the material. Thanks for the info.
/ Snow chain hitting my frame. #17
Could you swap the rims left and right, some have a different offset to widen or narrow the wheel track.. if this was mentioned , sorry i missed it..This might add enough room for your chains.
/ Snow chain hitting my frame. #18
Those spider bungies are sweet! I'm going to call them tomorrow to see if they make a set that will fit a tractor tire. I had clearance issues also and got the tighteners that are in the attached picture. Since then I moved my wheels out and now have good clearance. Problem is, these the top of the line spring tighteners work great but take as long to put on as the chains do. That spider bungee would be all I need now.
PS here's also a picture of my buddy when we moved the wheels out... left is in, right is out.
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
more info coming soon (A61569)
more info coming...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2017 International HX620 Quint Dump (A62613)
2017 International...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
