3 point hitch stuck on M8540
   / 3 point hitch stuck on M8540 #1
shooterdoc
farmall 450
New tractor (100 hours). New Meteor snow blower with hydraulic chute. Used the snow blower for the first time today. Moved a bunch of snow. Raised and lowered the 3 point several times with no issues. Raised the 3 point hitch/snow blower to clean before put back into shed now it is stuck in up position. Any ideas?
Thanks,
Jay in Iowa
   / 3 point hitch stuck on M8540 #2
Thanks,
Jay in Iowa
Did you try rotating the drop rate control valve counterclockwise? If it got bumped (rotated) closed, the 3pt will not drop.
James K0UA
   / 3 point hitch stuck on M8540 #3
Yep, I'm with k0ua, you've probably closed the drop rate valve accidently. Not much else to go wrong there. Of course we both are assuming you have the draft control lever pushed all the way forward???
   / 3 point hitch stuck on M8540 #4
Those are the only 2 things I can think of that would cause that.
E/S
E/S
Checked both of those things (and the linkage to the control arm/lever). Still doesn't work. Thanks for the replies.
   / 3 point hitch stuck on M8540 #6
Sorry to hear that, I am thinking broken parts inside now. Piston stuck, something clogging drop valve orfice, something like that.. I see a teardown in your future.
   / 3 point hitch stuck on M8540 #7
Time to call the dealer.
E/S
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A50860)
2018 Mack PINNACLE...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
