3 point hitch stuck on M8540
   / 3 point hitch stuck on M8540 #1
shooterdoc
farmall 450
New tractor (100 hours). New Meteor snow blower with hydraulic chute. Used the snow blower for the first time today. Moved a bunch of snow. Raised and lowered the 3 point several times with no issues. Raised the 3 point hitch/snow blower to clean before put back into shed now it is stuck in up position. Any ideas?
Thanks,
Jay in Iowa
   / 3 point hitch stuck on M8540 #2
Thanks,
Jay in Iowa
Did you try rotating the drop rate control valve counterclockwise? If it got bumped (rotated) closed, the 3pt will not drop.
James K0UA
   / 3 point hitch stuck on M8540 #3
Yep, I'm with k0ua, you've probably closed the drop rate valve accidently. Not much else to go wrong there. Of course we both are assuming you have the draft control lever pushed all the way forward???
   / 3 point hitch stuck on M8540 #4
Those are the only 2 things I can think of that would cause that.
E/S
E/S
Checked both of those things (and the linkage to the control arm/lever). Still doesn't work. Thanks for the replies.
   / 3 point hitch stuck on M8540 #6
Sorry to hear that, I am thinking broken parts inside now. Piston stuck, something clogging drop valve orfice, something like that.. I see a teardown in your future.
   / 3 point hitch stuck on M8540 #7
Time to call the dealer.
E/S
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
2015 Ford F-550 4x4 Knapheide Service Truck (A48081)
2015 Ford F-550...
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
2014 International DuraStar 4300 26ft Box Truck (A48081)
2014 International...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
