I would think that by extending the bucket out that extra 6" would drastically cut down on the lift capacity. The lift capacity is only 500lbs and I would imagine almost everybody with a BX has easily maxed that out, but it is a good looking system. I like the first quickattach better, much cleaner setup, but much more work. It would be perfect if it was built to the specs of a mini skid steer then all sorts of attachments would be readily available.
I wanted a small tractor, sacrifices are made when you
buy said. That does not mean things can't be altered. I have
not the knowledge, currently, to even talk half way intelliegntly
about the following, but if anyone figures something out, I am
subb'd in.
Is there a way to increase the capacity of the FEL lift? The hoses
are 1/4"ID, w/ 3/8" fittings, meaning the fittings are 1/4"HOSE X 3/8"JIC FWIW.
The BH has plenty of power, I wish there were an extra 300lbs lifting force up front.
Can ya make a doubling pump, maybe connect a pony pump sumthing to
the MMM pto, plumb from the tractors pump to the pony pump and bump
up the pressure a tad?
Here is the website for that one. Tach-N-Go, Loader Buddy, small loader Quick attach and attachments
I believe the owner is a member here. It's a nice looking unit.
Indeed Jery is a gifted engineer and a nice guy to do business w/ as well, :thumbsup::thumbsup:
I was able to bump up the operating pressure on my BX which seems to help lift capacity. By how much I couldn't say but it might have been enough to make up the difference that the extra 6" these adapter add.
How were you able to bump it up?
Thanx guys...
I read that whole thread. Yep, yes and you bet ya on the warranty deal.
I need to figure up a pressure gauge I guess and check what I have anywho.
I never did see any clear BX25 pics of the PRV Hex nut, unless I missed it...
Another to do I guess.
The Tach-N-Go Q/A adds less than 4'' of offset.Here is the website for that one. Tach-N-Go, Loader Buddy, small loader Quick attach and attachments
Well this thread was revived by spam... but it got me thinking on the topic.
FYI there will be a factory BX quick attach. It has been mentioned in the literature for the new BX25D. It doesnt appear to add much weight or offset either.
Something for those looking for a BX QA (like myself) to consider.
