T 603 OVERHEATING HELP
/ T 603 OVERHEATING HELP #1
bha4424
United States
TYM
I HAVE A TYM T603 THAT OVER HEATS WHEN USING THE PTO AND OR AC ANY SUGGESTIONS
I WAS THINKING ABOUT A BIGGER RADIATOR ,ELECTRIC FANS AND A OIL COOLER BUT NOT SURE WERE TO GET THE STUFF THERE IS NOT AS MANY PERFORMANCE OPTIONS FOR AFTER MARKET PARTS FOR TRACTORS AS THERE IS TRUCKS SO WERE CAN I FIND THE STUFF AND IS THERE ANY THING ELSE I CAN DO ABOUT IT OVER HEATING :mad:
/ T 603 OVERHEATING HELP #2
I have a Mahindra 4510 which I am told is a rebadged TYM. It would get warm when the radiator got clogged which it did easily. I repositioned the battery and removed the windshield reservoir so there was more air to the radiator. I also blew out the radiator fins that had chaft in them. Made sure the belts were adjusted properly and added an electric fan in front of the radiator. No problems since but I think the radiator size and design and equipment/accessory placement was a poor design. It would work well in a clean field but not if weeds were present.
ok thanks ill try that aslo do you know were i can get a better radiator or electric fans or a over sized oil cooler or a cold air intake for the tractor ???
also would removing or drilling extra holes in the thermo stat help
/ T 603 OVERHEATING HELP #5
The shop just added an aftermarket electric fan with a manual switch to turn it on and off. It was quite reasonable. I added an extra oil cooler for my truck once and the shop just plumbed it in and it helped also.
what shop do you use there is not one close to me and when i call the nearest one they dont seem to be very good maybe i could order the parts and out it in my self it has a cat diesel maybe cat would have an oil cooler or could atleast tell me what size inlet and outlet i have
/ T 603 OVERHEATING HELP #7
Sorry about the late response. Christmas and all. I do not know where you live but Apple Farm Service in Botkins, Ohio has always been fair to me.
Sometimes some of the high school ag shops will do projects over the winter but often they have the tractors for a number of months.
No big deal , thanks i'm in Texas do you also have the cat diesel and do you have the part numbers they used
/ T 603 OVERHEATING HELP #9
At one time my mitsubishi grey market tractor began to have the overheat issue.I bought an electric fan from Advanced Auto Parts and installed it in front of the radiator and later I realize the problem was the clogged fins in the radiator ended taking it off.Now I use compress air to clean my radiator every time I,m going to use my t293 as part of my pre-check ritual.
/ T 603 OVERHEATING HELP #10
No I do not have the cat diesel, it is a Korean diesel engine I think. Unsure about the fan part number.
/ T 603 OVERHEATING HELP #11
I had the same problem the radiator between rad and a/c condensor was full of chap even though I blew it out with air.Ended up unbolting a/c condensor to be able to get in there to do a good cleaning.Fixed the problem
/ T 603 OVERHEATING HELP #12
I also have the same problem. Very poor design. What really bothers me is making a good radiator is not a new science. I had an Oliver before this tractor and never overheated not matter the situation. I think I blew it out once in about 5 or 6 years of ownership. A good friend of mine farms with older tractors and I asked him about it and he said unless really extreme conditions he cleans his radiators once a year in the spring and never has any problems. My honest opinion is that they put in cheaper radiators to save money and I hate to say this but I think if your engine overheats and needs repaired or replaced they can say neglect on your part and not cover under warranty. Then they can sell new parts or maybe a new engine to you. Don't like to be negative but it would not surprise me if true but could never be proven I am sure.
I did take off the side panels during the summer and it helped quite a bit. Just very frustrating when you can not go and mow for a couple of hours without stopping to clean the radiator. It does help to wash it out with water but be careful of high pressure because it will bend the fins.
Dan
/ T 603 OVERHEATING HELP #13
Make sure that there isn't a bunch of dirt and chaff in the radiator air side passages, that the belts are tight and the rad cap is working correctly and has the correct pressure rating. make sur the air filter is not clogged. Check to make sure that the lower hose does not collapse when you increase the rpm.
/ T 603 OVERHEATING HELP #14
A common cure for compact tractors is installing a larger lower radiator hose. Make sure you have flushed the coolant replaced it with new at the proper summer mix. Flush out the heater core. These compact diesels run a higher oil pressure and a Higher RPM range witch would shake apart the older diesels. Make sure you are using proper engine oil for the summer should be 15 W 40 summer time temps over 77 degrees you should use S.A.E. 30 weight and 10 weight for below freezing temperatures your coolant should be ethylene glycol mixed 50/50 ...
Good Luck
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2019 ASV RT-25...
PIPEHUNTER HYDRO EXCAVATION TRAILER (A65643)
PIPEHUNTER HYDRO...
12V YARD SPRAYER (A64278)
12V YARD SPRAYER...
2007 Ford Explorer Sport Trac Crew Cab Pickup Truck (A64556)
2007 Ford Explorer...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
2009 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A64556)
2009 Chevrolet...
