What is this tool?
/ What is this tool? #21
with the points dull it is not for logs. With the adjustment holes I would suggest it is for picking I beams and such
/ What is this tool? #23
Yes, true steelyard scale is like that, but, this one in original post looks very like a scale. Maybe, it is just with missing weight ball (whatever called) - maybe, just an homemade with some calibrated holes for quick weighing.
/ What is this tool? #24
I'm a twelve year journeyman industrial scale tech.
This is no scale.
Not even part of a scale.
It lacks the basic priciples that would make a steelyard scale.
and
This could be nothing more than pieces of junk that someone threw toghther trying to invent or make a tool.
The two arms with hooks on the end don't even match. they look completely different.
/ What is this tool? #25
I also believe it is a chain dog. The first hook is clearly designed for the chain loop to be captured by sliding chain link into it. The second hook with the pointed end goes into the eye of the chain allowing the chain to be pulled forward.
/ What is this tool? #26
that is an antique ''come-a-long'' . those are chain dogs
So it's an early incarnation of a chain binder?
/ What is this tool? #28
Turn lower hook 180 degree to see it clearly. (no, 90 degree counter clockwise direction)
It is an old style weighing scale.
I thought of that but it doesn't look like a yard. "yard" is the name for those type hanging scales. Oddly, I can't find anythign on google.
later: I see someone else correctly named that type scale "steelyard".
Harry K
/ What is this tool? #29
We have all missed the obvious.
It is the Mark 1 muffler bearing.
Harry K
/ What is this tool? #31
Looking at it- top hook is designed to snag a cogged tooth on a steel wheel. The hook below looks like it can be driven into wood. It looks like the handle is missing.
/ What is this tool? #32
on a recent HOW ITS MADE show, They were making wooden wagon/ buggy wheels. the wheelrite used a tool like this to spread / pull , the spokes to align with the hole in the outer rim. it had a handle, maybe the different holes are to adjust for larger or smaller wheels [distance between spokes].
/ What is this tool? #34
just some parts bolted together?
arms look similar
/ What is this tool? #35
Even the oldest steelyard scales had some type of pivots and bearings.
There are no pivots or bearings.
A steelyard scale is suspended by a handle or arm with a bearing on the end
The beam of the scale has a fixed pivot and a second spaced at a percise distance to calculate a ratio commonly 10:1
ex. 100 lb object to lift a 10 lb ball on the arm, bar lengths vary and ratios vary
The steelyard rod hangs from the second pivot on a second bearing
The object being weighed is hung from the steelyard rod
The poise weight or ball is moved until the bar balances
Marks along the bar indicate the weight where the ball or poise weight allign
Most scales had hooks commonly used for weighing meat, furs or burlap bags filled with goods.
With no counterpoise weight on the beam and no object weight on the hook the beam must level out and balance.
/ What is this tool? #36
Common logging tools and Wheelwright spoke tools
z cant hook.jpgz clampplateandspokeclampfig82-83.jpgz hookaroon.gifz peavy.jpgz springing spoke tool.jpgz springingspokesfig173 2.jpgz timber carrier.jpgz timber jack.jpg
/ What is this tool? #37
I believe it's for lifting beams (metal) if it was for wood it would be sharp at both ends, this is flat with a lip, as one thread mentioned it could be for railroad trak, the little metal handle could of had wood over it at one time or it could be a handle for placement...
/ What is this tool? #38
It doesn't look like it's origins are cant dog or peavey - but it sure is a nice one!
iDrive TDS-2010H...
2020 ATLAS 2 POST AUTOMOTIVE LIFT (A59909)
2020 ATLAS 2 POST...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2020 ASV RT65 (A60462)
2018 CATERPILLAR 289D SKID STEER (A62129)
2018 CATERPILLAR...
