Controlling Warpage when Welding
/ Controlling Warpage when Welding #1
ChuckE2009
Goodmorning everyone!!
Well, I've been pretty busy here lately, I havent gotten to spend as much time out in the shop as I'd like to...
Anyway, over the past couple years I've picked up a few ideas about dealing with welding related warpage here on the internet, from both schools I've attended, and from my own personal, but limited, fabrication experience....
One night, I decided to make a video about the subject, and this is what I put together...
I told myself, "I want to make the video I would have liked to seen when I started building things" and this is what I came up with.
Just wanted to share, hopefully it helps someone out:
Have a nice week, everyone!! :cool:
/ Controlling Warpage when Welding #2
Great video, great explanations and pointers. I have been welding for 30 years and have learned something today. Thank You.
I have straightened some large trailer "truss" sides I manufactured by using a torch. The sides warped even though there was little welding done on the web connection portion of the truss frame. A little carefull application of heat from the torch and pulled everything back to nearly perfectly straight. I hope you keep up with your videos because you do an excellent job. Your welding instructors should be proud.
/ Controlling Warpage when Welding #3
Very good, I really enjoyed the video.. Who says a 58 year old guy can't learn something from a 19 year old.? Thanks again, and keep 'em coming:thumbsup:
James K0UA
/ Controlling Warpage when Welding #4
An ounce of prevention is worth more than a pound of cure! ;)
/ Controlling Warpage when Welding #5
When are you going to do a video on heat shrinking? :cool2:
I'm here to serve :D
Thanks man :)
James K0UA
Haha, glad you liked it :cool:
When I get good at it, lol!! I've read up on it, but I've never really practiced it :eek:
/ Controlling Warpage when Welding #7
The best way to learn is to do it with projects. I got stuck building 200 of these one time. Can you believe it was written in the specs to have the legs no more than 1/16-inch out?!:rolleyes: I'm sure you know square tube is very reactive to heat. Every one of these I had to heat shrink back on dimensions.
/ Controlling Warpage when Welding #8
Every time you have welded you have praticed but only in the bad kind of way. Take a heavy piece of steel and heat a pie shaped portion red hot and then let it cool...
/ Controlling Warpage when Welding #9
For small objects I like to use a spray bottle of water. Large beams I'll use a water hose.
UNUSED ATS POWER ATS-GAC40Y 40 GALLON (A64281)
UNUSED ATS POWER...
Caterpillar 120G/130G Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
2001 Wellcraft Boat w/ 2000 Boat Trailer, (A61574)
2001 Wellcraft...
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
2019 INTERNATIONAL 4300 26FT BOX TRUCK (A59912)
2019 INTERNATIONAL...
