Tree Felling danger
/ Tree Felling danger #21
That's what is called a 'barber-chair'. Certain species of tree with specific grain structures are especially prone to this, ash being one of them. Leaners are even more prone to this, because of the extra stress on the holding wood during the backcut.
See this thread for a good explanation and some tips: http://www.arboristsite.com/tree-care-videos/177328.htm
With a lean you need to make your face cut then plunge through to make your hinge (being careful of kickback and not leaving your hinge too thin) then cut from hinge to the back instead of from the back in.
You can also chain the tree above your cut to help prevent it from splitting out.
:thumbsup::thumbsup:
I cant add much.
/ Tree Felling danger #23
Yep. Dont "lollygag" on the back cut, but you also have to be mindful to leave enough hinge. You dont want to power through and leave no hinge at all. That can be just as dangerous as a barberchair.
/ Tree Felling danger #24
Cut through the hinge and you have a box of chocolates. :eek:
Wrooster
/ Tree Felling danger #25
The longer the dead (EAB) Ash stand, the more prone to barberchair they become. Once the bark starts to split and fall off, the log will check, in some cases I've seen it go all the way to the pith. Turns a slight leaner that would have been an easy drop into a widowmaker.
Ed
/ Tree Felling danger #26
View attachment 286311View attachment 286312View attachment 286313So I was going about my usual logging. I was cutting an ash bout 18" at the butt. The tree was leaner so I was confident of direction of fall. Before I finished the cut the tree "BLEW UP". Never seen anything like it. Once my razor sharp reflexes kicked in I fell backwards and planted my face in the ground. :rolleyes:
There are several scenarios for 'widow makers'. Add one to the list.
I am a bit of a naysayer when I hear all accidents can be prevented, sure they can, stay in bed. I am by no means a professional lumberjack but I have cut allot of wood with a chainsaw in my 50-years. This weekend I almost got taken out by a 8" 40' tall dead cedar I could finally get at due to the low water level in our pond. Easy tree, leaning the way I wanted it to fall, perfect hinge, except when I went to step back from the tree my foot was stuck in the mud. My lighting reflexes dropped the saw and I grabbed the trunk with my right hand as if I could stop its momentum. Physics took over and threw me on my butt which jammed the heck out of my wrist but fortunately knocked me out of the way. Fact is none of get out of this alive and we all should raise our beers to dumb luck and not try to over analyze every situation. Glad you and I were not seriously hurt. Maybe next weekend :laughing:
/ Tree Felling danger #27
NO OFFENCE TO ANY ONE. NO 1 TREE IS THE SAME IVE CUT THOUSANDS OF TREES NOT ONE WAS EVER THE SAME
/ Tree Felling danger #28
I always wrap a big chain (1/2 in) around the trees that are leaning about 12" above my cuts to reduce the chances of it exploding.
/ Tree Felling danger #29
Ain't that the truth, no tree is ever the same nor are the variables that come into play like lean, terrain, wind direction. equipment...etc....
Same for me after felling more trees than I care to remember....Cutting down trees is a unique exercise, with each tree there comes new learnings/considerations/approaches.....sure you can minimise the risk with experience, preparation & planning but you can't be complacent to believe you totally mitigate the risk....
/ Tree Felling danger #31
I learned to chain leaners a few years ago, after watching a few barber-chairs on Youtube. Small slow saws are killers too... the longer you spend behind the tree making the back cut the longer you're exposed to danger if a gust of wind catches it.
Sean
/ Tree Felling danger #32
I used to plunge cut almost every tree just to get some practice, and you can also start your wedges on a tree thats leaning back. With a proper sized hinge and back strap the tree is very stable. I took a weekend chainsaw safety and felling course and its the best money you can spend if you are going to use a saw.
/ Tree Felling danger #33
I knew of a weekend warrior homeowner who decided to cut a 4' leaner without listening to advice given him or getting a pro. The tree exploded and decapitated him.
/ Tree Felling danger #34
Lots of good info here, but nobody discussed the notch.
It's hard to judge in those pics, but I don't see much of a notch on the stump. Having no notch or too little of a notch can dramatically increace probability of barberchair. Essentially this creates too much holding wood. When wood is "held" and not free to hinge over, the momentum and pull of the canopy will split the wood along its grain (barberchair).
/ Tree Felling danger #35
Even a too shallow notch will do it. My only real barber chair happened that way. Tree fell correctly until that undercut closed and then it split.
Harry K
/ Tree Felling danger #36
I can't tell from the picture but it looks like the notch was at 90 degrees? On the beheading I mentioned above, the guy had no notch what so ever. It was his first and last tree he ever cut.
Caterpillar C18 Industrial Diesel Engine - Serial N8F01121 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
2023 ANDERSON IFX720 CONTINUOUS BALE WRAPPER (A64277)
2023 ANDERSON...
2008 New Holland T2420 (A60462)
2008 New Holland...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
100 gal L Portable Fuel Tank (A66408)
100 gal L Portable...
