Track'd CATs
/ Track'd CATs #1
CA Grown
Central California
John Deere 6520L
Can anyone explain to me the differences between the CAT CH45/55 series tractors with the Challenger MTB155 (probably grossly wrong)?
I mean, I get it, but the price deference makes me scratch my head. There's got to be a serious difference, no?
Would a CH55 be just as good as the equivalent Challenger model?
It'll be my first belted tractor and its kind of a new world to me.
/ Track'd CATs #2
We've previously run various Challengers from a new Cat 65 in c.1989 to more recently MT865's.....with no till/minimum till farming IMO the advantages of belted machines have been largely superceded by changes in farming practices.......arguably it's only in lower compaction no tramline farming & getting into wetter fields marginally quicker where belted tractors now have any competitive "edge", & these can be equalled by running triples on wheeled machines...
/ Track'd CATs #3
Also the ride difference is amazing. You dont feel ruts or wheel tracks etc. Its like your driving on a fresh paved road. With tracks you also get better pulling while you keep compaction at a minimum. Does it have wide or narrow tracks?
/ Track'd CATs #4
True you can achieve greater drawbar pull with a belted tractor, but the extra lugging comes at a cost of lower speed - for us "crunching the numbers" wheeled machines & matched implements pulled at a greater speed comes out in front over the higher running costs of rubber tracks on a cost/acres basis......all depends on your country, crops & cultivation techniques
/ Track'd CATs
It'll pull a huge lettuce bed former (5 beds wide). Compaction footprint needs to be at a minimum because if there's a rut, the bed former will pull in less dirt in that track.
It'll be wide track, I guess.
/ Track'd CATs
Speed isn't that much of an issue. We pull slow- it seems the bed former "floats" more whereas at high speeds it digs in more and the dirt starts building up clogging the machine.
To me, at 30-50k, a CH55 is a good deal when compared to the MTB series (I'm sure I'll keep getting that wrong, the model #'s) where those are 130k+.
Which is why I was wondering, what's the big difference? Are the CH's that undesirable to the point that they command a far lesser cost?
/ Track'd CATs
Seems I'm not the only one in the dark as to the differences between the CAT CH series and Challenger series.
:lol:
/ Track'd CATs #8
Just a quick comment on the pros/cons of belted tractors: The belted will, under some conditions, be more prone to slippage than a wheeled tractor. An example is in crop stubble that has a slippery texture. The less PSI footprint of the belt will actually tend to slip more in this condition.
/ Track'd CATs #9
:lol:
The Cat CH55's generally had a reputation for low engine & track life, & relatively higher fuel consumption - they didn't tolerate abuse well - & the engines were wound up & stressed to met the rated HP demand.
On any S/H machine make certain to get an oil sample prior to parting with the $$$$ & apart from checking the sprockets/idlers/rollers, the track tensioner & track frames can fail on higher houred machines.
In all respects the MT series (e.g. MT745) is a far superior machine, but worth the extra substantial $$$$'s ? That only you can answer in your operation/ application.
/ Track'd CATs
That's what's killing me. I see the CH's around all the time. A friend of mine has one and says nothing bad about it. That's why I'm thinking, heck, I could do the same.
I'm not hard in equipment. It won't be used for any heavy ground work (like deep ripping)- just discing and toothing. Then for pulling a bed former. Nothing I'd consider heavy stuff.
After reading, the tracks were an issue for me as far as life. I guess that's something (along with the rollers) to pay special attention to.
Oil analysis is a given. How were the engines? You said they break? What exactly is the issue there?
/ Track'd CATs #11
Ours were used in dryland broadacre applications, often under consistently high ambient temperatures (usually c.100F) predominately in seasonal 24/7 operations -direct drilling operations (for grain crops) & secondary cultivation
We found the turbo's didn't last long as the bearings fried/collapsed regularly & the best we could get out of the engines in the Cat 55/65/85 were c.6000-7000hrs before major rebuilds - we also had the 55 break a crankshaft at c.4800hrs & burn a piston prior at c.3200hrs, so maybe we had a dud.....
Comparatively the MT's ran without issues (except high track wear & a couple of collapsed track gear bearings), to c.6000-8000hrs before we exited from belted tractors, we're not hard on equipment as is evident from our older gear with high hours :
- an old Steiger 400hp with a CAT3306 still purring away at 29000hrs
- 2x White 4-150 with Cat 3208's fine @ c.12000+hrs ( a lot of people don't like the 3208's but we've always had a good run from them including in trucks & pump sets)
- 3x Acremasters 330hp mercedes V10's all fine @ 20000-36000hrs
IMO the CH55 should be ok for pulling your lettuce bed former (as they performed well in cotton on well tilled ground ) & discing, but if it's hard ground I'd be a little cautious on any heavy tine work ( like chisel ploughing ).....the rubber tracks usually wear ok in black/alluvial type soil (make certain to keep the rollers/idlers clear of soil at each day end) but experience exponential wear in granite or sandy loams....
2025 Hydraulic Stump Grinder Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
Caterpillar Specification Manuals Vol. 3 Books 1 and 2 (A63117)
Caterpillar...
2020 ATLAS 2 POST AUTOMOTIVE LIFT (A59912)
2020 ATLAS 2 POST...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
Caterpillar 914G/IT14G Wheel Loader Parts and Service Manuals (A63117)
Caterpillar...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
