Chainsaw - Sharpening Chains
/ Chainsaw - Sharpening Chains #41
I just some here know the difference in a rat tail file and a chainsaw file. I have never used or seen anybody use a rat tail file to file a chainsaw chain. With that said, I use a cheap harborfreight grinder all the time. I can change a chain as fast or faster than I can file a chain by hand so I take several with me when I am cutting wood. When I get home, I grinde the dull chains, but then I always hit them a couple or three licks with a chainsaw file. I have found that the grinders do a good job of squareing the chain back to the right angles, but it also seems to leave a little burr on the tooth just sharpened. If i take a file and knock this burr off, the chains seem to cut better and stay sharp longer. Works for me.
/ Chainsaw - Sharpening Chains #42
I've had a Stihl since '94 - been through 2.5 bars and a handful of chains. Sharp chains are wonderful. So it money. I look at the cords of wood I cut each year as purchased at the depreciated cost of the chainsaw, its parts, other equipment, etc. I like to keep it cheap. Stihl makes a fantastic saw. I have it tuned professionally every 5 years. I carry a chainsaw file in the case with the saw. I "touch it up" whenever I feel it slowing or curving in the wood. After I file it 6 to 8 times, I swap the chain out and keep going. I always have 3 or 4 since I'm usually well away from stores. The dulled blades are checked in my shop. If they appear not too bad, I may bench sharpen them by hand. Most of the time I take them to a local Stihl dealer who has always been good. I pay $5 or $6 for sharpening - 18 inch blade. When blades get thin and can't be sharpened again, I keep 'em around for use cutting wood that is contaminated with rock, dirt or fence nails.
Looking at the amount of cutting I do - using wood for supplemental heating only - and donation to charity - my little system seems to most efficient and economical way to do it. But, as this thread shows, there are many correct opinions on keeping blades sharp - and many ways of cutting wood.
/ Chainsaw - Sharpening Chains #43
I use the Dremel all the time. I used to have the little guide attachment, but it disappeared and I didn't really need it anyway. I have a 12v model, and carry an old lawn tractor battery with me. It works great. It's not much to carry and I don't have to remove the chain from the bar. If I am working with the Bobcat, I have a little extension cord that clips onto the battery and that's all I need. I have one of the Northern Tool bar mounted 12v grinders, but it's a lot more work to set up, and I can do a 20" chain in just a minute or two with the Dremel.
/ Chainsaw - Sharpening Chains #44
This sounds like a good job for the elcheapo Harbor Freight chain saw sharpener. It will pay for itself on the sharpening of 2 chains if you are paying someone to sharpen them. It worked well for me on some chains that had hit some fencing and rocks when clearing the fence line. They came out good as new. Very simple to set up and adjust so it just takes a small bit off each tooth(just a few sparks). The plastic housing has a little flex to it which is good for putting a little side pressure on a tooth that has a ding. DONT have to adjust the machine that way for just a tooth or two. Set if for the average cut needed to sharpen and when finding a tooth in need of a bit more, just put a little side pressure on the machine, it doesnt take much just enough to remove any burr that might be there from hitting metal or rock.
i have a harbor freight chain sharpener have had it for about 3 years and i couldn't be happier.i wish i would have bought one years ago.
/ Chainsaw - Sharpening Chains #45
Once the bar is clamped into the vice, a tooth is marked as the starting point, the chain moves freely on the bar, yes I can do one pass with a file per tooth on a 20 in bar in just over 60 seconds. I really don't give a rats rectal orifice if you believe it or not, as to make a comment like that you are quite likely a rectal orifice yourself.
I think my 20" chain has 72 drive links if i remember right, doesnt that mean 36 cutters? thats 2 seconds a tooth! doable but really moving!!
/ Chainsaw - Sharpening Chains #46
Interesting opinion - funny thing is I can't recall seeing too many loggers using bench grinders on the tree line......could be prove to be quite an education if you choose to call these guy's "kids" View attachment 293278 .......But I guess if you're felling toothpicks you don't need the accuracy of hand filing .....:sarcastic:
I dont see loggers in the woods with grinders either, but they do take them off every few days and sharpen them in the shop on one!!!
I am a forester so i deal with quite a few loggers!!
/ Chainsaw - Sharpening Chains #47
With all these opinions, doesn't anyone else use the Dremel sharpening tool? I like it because it's quick and I don't have to take the chain off the saw. I used to hand sharpen, but the Dremel is so much faster and more accurate, and costs so little if you already have the Dremel tool, I don't see a reason to do it by hand.
My cutting buddy uses one and swears by it, but for some reason i always am still cutting and he is out saying my "saw is so dull im doing no good". This is while i hand sharpened and esp now that i grind it. If you grind you can still just kiss the tooth to get it back sharp, that is unless you got in dirt or hit rocks and got to get a chip out or something. Well he uses one of those electric hand jobs which is basically a cheal low powered dedicated dremel type tool with chain sharpening stones in it.
Also i have a still rollomatic bar and it has no greese hole to fill!!
/ Chainsaw - Sharpening Chains #48
What is a "blade" sometimes it sounds like your referring to your bar and others your chains? This is very confusing. Seriously im not poking fun at your terminology.
/ Chainsaw - Sharpening Chains #49
YES - there is only ONE correct way - the way that works for the guy with the chain. I know guys that wouldn't touch a grinder but only file, guys that won't file but use a grinder, and guys that only buy new chains. They all saw wood well.
Keep your rakers low, your top plate angle correct and your cutting corner sharp.
Now dont forget those of us who just throw the saw away when the chain gets dull and buy a new saw:laughing:
/ Chainsaw - Sharpening Chains #50
Has anyone tried that Oregon PowerSharp thing? I don't know if it's just a gimmick or not and don't want to be the first to try it. It's where the special chain is purchased with a sharpener you mount to the end of the saw and the curved stone in the sharpener sharpens the top of the teeth. You push down while throttling the saw for a few seconds and it sharpens the entire chain evenly.
/ Chainsaw - Sharpening Chains #51
From what I have heard, it is an "ok" set-up for a homeowner. It pretty much works as advertised. But the given design of the chain, it dont cut as fast as a standard chisel chain. AND it is more expensive, AND it dont last as long. Thats why the big-boys dont use it.
But if you have a saw that you just use aaround the yard to clean up an occasional limb, it is a good product and quick and easy for a homeowner to use vs taking the saw or chain somewhere to get it sharpened.
/ Chainsaw - Sharpening Chains #52
I do -- but I use the version of one. it works good for me, but after a few sharpening, I might have to regrind back to correct angle.
/ Chainsaw - Sharpening Chains #53
I used to sharpen saws with a file and have files, angle gauges etc, but with old age comes not necessarily laziness but a will to do it easier. TRIFOCAL glasses dont necessarily contribute to good saw filing either. I can remove the chain, put it on the little sharpener and grind every tooth in less than 10 minutes on an 18" bar. It takes me at least that long to do with a file sometimes longer depending on how many cramps I get in my hands. Using a file to sharpen a saw is indicative to using a mule to plow with, or slide rule rather than a calculator. It's OK if you're into that sort of thing but I prefer the new ways rather than the old way when it is as cheap to do as the HF sharpener and it does an adequate job for me. Maybe some folks can make them cut better than new but I never could and the electric sharpener gets every tooth perfect on angle and length everytime, it super easy to use too.
My cousin and I bought one and love it! I am a tri focal guy as well, lol. They come on sale every so often at Princess Auto, ours was reg $189 we got it for $100. We have about 8 chains between us and can get er done, if we have to, I guess lol.
/ Chainsaw - Sharpening Chains #54
I got mine on sale at PA too. :thumbsup: Its a handy tool. Well made also.
/ Chainsaw - Sharpening Chains #55
That's what I use. Had an old Craftsman branded single speed rotary tool with the same collar thread as the Dremel. The $13 Dremel kit with the guide works perfectly with it. Takes just a couple of minutes to nicely sharpen a chain, and I like being able to leave the chain on the saw. Great little kit, simple to use.
/ Chainsaw - Sharpening Chains #56
Used the Dremel for the last 12yrs. and it works great. Simple and effective
/ Chainsaw - Sharpening Chains #57
I'm confused about some of the posts where people talk about using both round hand files and bench models. Can you go back and forth between a round hand file and a bench top sharpener on a round ground chain? I thought the bench grinders put a flat grind on the tooth? At least that has been my experience when I turn them in for sharpening: turn in a round ground chain and it comes back flat ground. Do the grinders use the side of the disk or the edge? I see some grinders advertise they work on all sizes of chain? If it is round ground how do they accomplish that unless you are swapping out to thicker or thinner disks? Also, do the bench grinders work for lower the rakers and if so can you do it during the same set-up pass or do you have to readjusts the grinder and run around again? Just curious, I've had good results with a dremel and/or hand file but I'm also wondering what I'm missing out on.
/ Chainsaw - Sharpening Chains #58
I cant talk about the rounded chains, I dont use them. As to the hand files. A chainsaw file is made in a specific dia for the size chain it is meant to file. Different size chains require different size files. Someone early in this thread mentioned using a rattail file to sharpen their chain. A rattail file is tapered in shape and isnt meant to be used for sharpening a saw chain. A chainsaw file will retain its shape (ie, Dia) for the full lenght of the file and wont be tapered.
Bench grinders also use specific grinding disk for the size chain they are to sharpen. This hasnt been a real problem for me since I dont grind the large 3/4 chains. My grinder does sharpen on the side of the disc and except for grinding angle, I dont think there is any difference in the way a round chain is ground versus a square tooth or chisel tooth chain is ground. Again, I dont use a round chain so I cant be sure.
As for grinding the rakes on the chain, My cheap grinder isnt made for that, but I have been experimenting doing so on some worn out chains. I set the grinding disc on zero angle and the depth gauge to just taking a little off the top. Not the best results. I have also tried to cut just a little off the backside of the rake, (the side facing the cutter), which also lowers the overall height, but I aint satisfied with that method either. For me a flat file and gauge works best.
/ Chainsaw - Sharpening Chains #59
What mudstopper said +1
Keep in mind most people only have 1 or 2 chainsaws at the most, and if you are smart about it (and it makes sense for your needs), they both have the same pitch/thickness chains so you only have one sharpening setup. So worst case you only need 1 or 2 different grinding wheels and sets of files. .325 and 3/8" are the most common pitches people will run into...
/ Chainsaw - Sharpening Chains #60
Do people have something against progressive lenses? I use dime store glasses or my fancier progressives. It would seem that with progressives you can see the dull teeth you are looking at and the sharp result from hand filing. I am happy with the hand filing using a rudimentary Oregon file holder and their raker guide. I did supplement it using some calipers just to get length correct on a new to me saw that looked like someone was cutting dirt with the saw. I am trying to contribute to the TBN tangent thread theme.
Upright SL-20D Electric Scissor Lift (A64911)
Upright SL-20D...
2019 INTERNATIONAL 7400 SBA 6X4 DUMP TRUCK (A63276)
2019 INTERNATIONAL...
Landmaster L7 (A64912)
2014 Ford F-150 Pickup Truck (A66736)
2014 Ford F-150...
1991 26ft Pursuit 2350 Walking Around Cabin Cruiser with 2017 21ft S/A HMDE Performance Boat Trai... (A66738)
1991 26ft Pursuit...
2007 INTERNATIONAL 9900I (A67714)
2007 INTERNATIONAL...
