What would you..
/ What would you.. #11
A video camera so you could watch an implement's behavior while facing forward. Power it and use a joystick to rotate 360 degrees as needed plus zoom. sits on top of cab/rops.
/ What would you.. #12
On the Kubotas, I would like to see the brake pedals moved to the opposite side of the go pedal, built in hi-power back-up (work) lights, and a heated seat option would be great.
/ What would you.. #13
I would the engineers to realize not all tractors run on a level clover field and put the hydaulic lines and filters above the bottom of tractor.
FEL connectors really don't need to be hid under the floor pan. and the hoses draped under the frame .
The fuel fill cap why 2" below the hood and then a cover that prevents filling except one direction. I would also like a fuel indicator that reads the level rather than always "Low Fuel"
And fault code that says what is the problem instead of code requiring a book kept in the shop. Telling you the left blinker bulb is bad.
For the John Deere owners would need the MX 5-6-7 rotory cutters to have a output shaft to be made of steel instead the left over junk from China.
I am biased I know but the question was asked.
ken
/ What would you.. #14
A shutdown timer for diesels with a turbo, so I do not forget to let it idle a couple of minutes before shutting the key off.
An electric powered auxillary hydraulic pump piggy backed onto the hydraulic system so I can move my three point hitch, loader, or anything connect to the SCVs without having to start the tractor.
/ What would you.. #15
those pedals are the only thing that turned me to the deere.
What were they thinking:confused3:
/ What would you.. #16
That is a great idea on the shutdown timer.
It would be very doable with a relay timer and then have an emergency kill stop "just in case"
/ What would you.. #17
I think that auto connect hydraulics with a 3 point quick hitch is a doable option along with FEL auto hydraulics.
/ What would you.. #18
How about optional down pressure for the 3pt hitch. Nothing like trying to drill holes in hard ground when the digger just sets there and goes round and round without removing any dirt.
/ What would you.. #19
Not familiar with the 'botas, but on my deere the throttle is a small pedal below the brake pedals- clutch on the left. You can move the hand lever to any position to hold a certain RPM, but if you want foot control, you must use the small pedal. This isn't really any different than driving a car or truck. I have never found a problem with it as I rarely need to push both at the same time, and if I do I can just use the hand lever.
I am assuming you mean the hydro pedal is on the same side? If so, then what is on the other side? I know very little about newer tractors.
/ What would you.. #20
On my Kubota L3400, I would like a dipstick, rather than a sight gage for the hydraulic fluid. Or at least a sight gage somewhere where I can see it.
207269 (A52708)
207269 (A52708)
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A61307)
Adams Load Out...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
