MF 135 Power Steering leak from top of column
/ MF 135 Power Steering leak from top of column #1
gjpat1
Grand Junction, Co.
MF 135
Hello everyone, have searched this site for info on P/S leak but havn't found much information. Hope I'm not repeating someone else question. I just bought a 1965 MF 135 tractor with a gas engine. Was told the tractor hasn't been run for more than 10 years. Hoping to do a good restore on it.
Got it running with very little work, but no power asst. on steering. Filled P/S pump, and all the oil got pumped out of a litle vent hole in top of steering column. Pulled column and replaced o ring and seal, as soon as I started the engine, seal popped and started leaking again even before I could turn the steering wheel.
Pulled the return line at pump, good flow coming back to pump, pulled control valve, can't see any visible cause in valve. Anyone know what I should look for next. Thanks for the help in advance.
This tractor does not have seprate hyd rams at each front wheel, the asst. ram is tied into the back of the steering gear. Thanks. Pat
/ MF 135 Power Steering leak from top of column #2
:welcome:
/ MF 135 Power Steering leak from top of column #4
you may have to rebuild the steering cylinder. Do you have a service manual?
Yes, that was the first thing that I bought.
/ MF 135 Power Steering leak from top of column #6
Sounds like a bad relief valve in the pump..
Thanks for the information, I have the system drained so I will check the relief valve tonight. Ive attached a pic of the beast the way I found her in the field.
Pulled the pump, cleaned and striped it down, unscrewed relief valve but cant get it out. It moves in and out about 1/4 inch but gets stuck. Not sure whats going on, will work on it somemore tomarrow.
/ MF 135 Power Steering leak from top of column #9
The manual says this is not a reusuable part, so it must get damaged when removed. Did you check and clean the filter?
So the dealer says relief valve obsolete, not available. I guess I'm screwed will have to buy a new pump for $600.00. Yes filter cleaned and OK. Thanks
/ MF 135 Power Steering leak from top of column #11
Before you invest in a new pump. Dig a bit more as to the cause. If Shona13 is around, he might have some clues if he's worked on a PS unit before.
Good news, after soaking the pump in PB Blaster all day, tapping on it with a hammer and cleaning with brake cleaner and compressed air, I now have 1100 psi and power steering. Bad news is I now have bad leak out of air vent in top of steering gear when turning, so has to be a bad seal in top of hyd cylinder. Should not be to much trouble fixing that, I all ready have the tractor pretty much taken apart.
Thanks for the help, I'm sure i'll have more questions before this project is done.
/ MF 135 Power Steering leak from top of column #13
That is great news. I'm surprised the guy said that the relief valve was obsolete. They used that same setup on the 165 as well. PB Blaster is great stuff. I've used up a half can on mine on several occasions. I don't think I was any help. Good job.
/ MF 135 Power Steering leak from top of column #14
SOLVED for 29 cents... I put a new seal on the column ,didn't fix IT Then a $700 steering valve ,didn't fix IT did more things than I can even remember then I took 6 inches of 3/8 inch natural fiber rope for 29 cents took off the top bushing on the column (right under the steering wheel) wrapped the rope around the shaft took a 1inch piece of pipe and drove it below the weep hole. When I start it up it drips a little then no leak at all
FUTURE 60" PALLET FORK (A60432)
FUTURE 60" PALLET...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
Kubota L3300 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
Kubota L3300 35HP...
UNUSED KJ K1912 - 20' X 12' LIVESTOCK METAL SHED (A60432)
UNUSED KJ K1912 -...
(APPROX 25) 4X4 POST INSERTS (A60432)
(APPROX 25) 4X4...
