Grrrrrr
/ Grrrrrr #21
I learned after 2 weeks of messing with it when cold 2 pulls full choke then 1 pull no choke and starts every time after that it's a 1 pull start saw every time .
That's what I learned today. After a second trip to the dealer this morning, I get to the barn, and again, no joy. I could just not believe it.
So I cut what I could with the smaller saw and on the way home I stopped at the dealer again. Last time, strike three.
I asked him to watch me. And he said whoa when I pulled four times with the choke on. Apparently it won't start until the choke is then turned off. Strange but ok if I knew this ahead of time.
Dealer: I told you no choke after two pulls
Me: never heard that
Dealer: I guess I said it too softly.
Groan.
So...just like the not so grumpy old man said, just have to figure it out. Never had an engine start like that, they always fired off on choke, not off choke.
It's relative sensitivity to choke was blamed on emission control. Ok.
If it doesn't start tomorrow morning for me, I'm getting a new one, my mojo is shot with this one.
I've always started all my saws as follows: 1. COLD.... pull choke out, turn on ignition, put throttle lever on (that thing at the top of the handle that holds the throttle at about half), pull the rope till it "pops"...take off choke, pull again and it will start, then release the throttle lever. this works on all saws...HOT...just pull the rope once...BobG in VA
/ Grrrrrr
I put the new chain on the 450 today, it made more noise, a whirring noise, and while it cut ok, the bar smoked at the end. And when I compared old and new chains, not sure they are exactly the same, so going to
inspect further before I run them again. Used the big saw and even with a not perfectly sharp chain, it ate the logs easily.
Getting down to the bottom of the second full pile of logs. Might wait on making another unless I have a really cold winter day; right now it's mud city.
my new log holder worked quite nicely. Clearly one can't cut in the middle of the saw or it will yank the wood your way, but cutting where I think one is supposed to, near the motor, the logs just fell off zip zip.
Yeah, you have to lug the log to it, but this way nowhere near the ground, and the whole thing is visible.
now that I'm not flooding it, the 600 starts just fine.
/ Grrrrrr #23
Back to the dealer time. It sounds like they gave you the wrong gauge size for your bar. Continuing to use will damage the bar. Heat will build up quick. There are only a few size guages used on chainsaw chains. 1.1mm (.043")
1.3mm (.050")1.5mm (.058")1.6mm (.063"). If you have a mike check the gauge size on the old chain and the new one. I think you will find the new chain has a larger gauge.
/ Grrrrrr
makes sense, I had problems installing the chain, but got it to rotate smoothly by hand, so thought it had to be ok.
I had greased the bar tip and I think the grease in there was smoking, a canary in the mine that something is not right.
/ Grrrrrr #25
Glad you got the 600P sorted out -- that is a nice saw! In my experience, you'd have to try extra hard to make an echo hard to start, so I will bestow on you the honorary idiot of the day award. I give it to you with full accreditation as an idiot myself ;)
Does the 450 bar have any specs stamped on it? I agree, you should confirm the chain is the correct gauge. That saw would likely either be .050 or .058 depending on how it was originally equipped.
/ Grrrrrr
I have the saws at a remote location farm, where I am a p/t caretaker, and so I can't just go look at it now. Which I am certainly curious to do.
In the meantime, as the rain keeps everything muddy, I will think of some nice woodpiles made elsewhere. I hope you all enjoy this as much as i did.
I'm also repeating an earlier pick I posted showing how pretty just plain big rounds are. Now would I go back and rearrange them all to make a picture?
No. The eastern european ones are seriously nice looking. Do they start at the very top when they go to consume the pile, or just bulldoze the pile down and haul it off?
Sure looks better than giant piles of cut firewood normally does, and seems to be designed to handle heavy snows successfully.
The smell of the wood as it's sawn or split, the clunk of the wood against itself, testing its hardness, and then the smell of the wood when it burns. All good.
And now woodpile art. I'm sure this isn't new but it was for me.
/ Grrrrrr #27
Suprised by another Echo. I took one in trade yesterday that hadnt been started in years. I took it as non runner. I pulled over slowly and it felt good. So I dumped the old mix out. Put in fresh. Pulled on choke till it popped about 3 times, pushed in choke and she took off.
Think I am going to like this little guy. 4500 45cc 11.2lb PHO. Oh the JD yellow colors is a plus because it goes with my echo 8000 in JD colors. 450V 800V
Big brother
/ Grrrrrr
too wet and foggy to be out today but did run my saws to the local shop where I bought them and they confirmed I had bought the next larger pitch chain from the other dealer.
Its the "more aggressive?" pitched chain similar to what was on the 24 bar, but sized for my 450's 18.
And it likely mucked with the bar a bit, which luckily I had thoroughly greased. But we both eyeballed the bar and the channel still looked pretty good.
Having two saws with two different pitches is something apparently I have to get used to.
/ Grrrrrr #30
You guys with the non starting reminds me of the guy who bought a chain saw because the salesman guaranteed it would cut 5 cords of wood a day. A few days later the guy brought it in said the salesman was a lying #$%%^ and no way could he cut more than a cord a day with it. The salesman couldnt understand it and thought if must not be running right so he pull the cord a couple of times and it fires up and runs perfect. The guy jumps up and hollers, "Whats that noise"
/ Grrrrrr #31
I like it.. Good joke,thanks
/ Grrrrrr #32
Maybe useful...
Most small engine repair people I know have a pattern to start unfamiliar equipment,, and I have noticed it is almost always the same. They choke to an over rich condition, and then take the choke off, and keep pulling until the proper lean mixture fires up.
I have found this to be almost universally reliable. I have started generators and other small gas engines that do not have primers on the carb, in below zero temps, by putting a tablespoon of gas on the air filter, (over rich), and then pulling until it leans out enough to ignite.
Maybe this is useful to some.
/ Grrrrrr
Ouch. Ok. life is a learning experience and some of us take longer...:)
5 cords, yeah maybe with an automated wood processor, but this guy was doomed to start. At about cord four he'd be dead with a massive coronary.
ok, where's my electric start chain saw? Not if it will come but when.
/ Grrrrrr #34
I have the same model log holder and love it. In some areas I get some 40' sun starved pines and firs with no branches and 6" butts. You can balance them and lock them in the holder, mark the cuts with a paint can, and work alternately from both ends. Takes a few minutes compared to lots of messing with a small tree otherwise. And it is much safer than trying to stabilise a small tree with your foot.
One thing that helps stabilise the tree in the holder while cutting is to lower the motor end of the saw so it is dragging down a bit more rather than straight sideways. Also, reefing down firmly to set the teeth more deeply in the tree helps. There is a good video on Youtube that shows these tricks.
/ Grrrrrr #35
I am clearing my land and I have 3 echo saws , cs-300/cs-520/cs-670 and the 300 is the best all around saw I have ever had but the 670 is a cutting machine just a little heavy but after the 20th tree of the day they are all a little heavy ! I used to be a stihl only guy but the cost of repairs and initial cost changed my mind , When I first got my 670 it was hard to start then I learned after 2 weeks of messing with it when cold 2 pulls full choke then 1 pull no choke and starts every time after that it's a 1 pull start saw every time . I love my Echo saws and have dropped over 600 trees this year with no repairs to any of them !:thumbsup:
That's a good testimonial for Echo. And you obviously know what you are doing with felling trees.
/ Grrrrrr #36
I think you mean "gauge". Pitch is the distance between drive links, guage is the width of the drive links. Pitch change would not affect the bar, only he sprocket.
Harry K
/ Grrrrrr
Harry K
thanks Harry, you're absolutely right.
2017 Hyundai Trailer (A62613)
2017 Hyundai...
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
International 154 Cub Lowboy, Gasoline, 60" Mower  (A62679)
International 154...
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
