Hydrualic quick connects the same?
/ Hydrualic quick connects the same? #1
300UGUY
Super Member
Howell, Michigan
Kubota L3400, Farmall H
I noticed a ad for a pressure gage set up for a hydrualic connector, sold for bx25's. I have a L3400, will the gage work on my connectors?
/ Hydrualic quick connects the same? #2
You can do it much cheaper than that kit!! ~$15 for the coupler and ~$5-10 for the gauge.
As to what coupler you need, I'm pretty sure the BX25 is a Parker 60 series. 1/4" threads. Model H2-62. (I'm positive its a 60 and 99% sure its 1/4")
Id imagine the L has a larger coupler, in that case the BX coupler in the set wouldnt work anyways.
Best thing you should do is go look at an existing coupler on your tractor, it should be stamped with what size it is. Then get the same and make your own gauge setup.
/ Hydrualic quick connects the same? #3
Print this PDF out to check sizes.
  • sizechart.pdf
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
2018 BOBCAT S470 SKID STEER (A62129)
2018 BOBCAT S470...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 John Deere 1790 Planter (A63109)
2013 John Deere...
2001 Chevrolet 2500 Service Truck (A63116)
2001 Chevrolet...
2018 RoGator 1100C (A63118)
2018 RoGator 1100C...
