Another 2210 U-Joint problem!
/ Another 2210 U-Joint problem! #1
steveschlutt
Member
St. Joseph Michigan
John Deere 2210
I'm a longtime lurker and reader, but seldom post. But today I need some help.
I have an '03 2210, 632 hours, and have the common and dreaded main driveshaft/U-Joint problem. The rear joint was fine, I replaced that one a few years back when I replaced the broken hydro cooling fan. But I've discovered that now the front one is shot, has mega-slop in it, difficult to tell yet if it has damaged the yokes.
So here's where I'm at-- after some grumbling and a few skinned knuckles, the machine is all torn down --ROPS, fenders, floor, kick-panel etc all removed. Rear u-joint is separated. But I don't see anyway to get up under there to separate the front joint, or get the shaft loose. If I could get the shaft out, I might have a good shot at this repair. I don't have a manual or diagram of the shaft-- does anyone possess that? What do i have to remove to pull the shaft off the front spline? Someone referred to a big C-clip and a Roll pin, but I can barely even see the shaft forward of the U-joint. How the heck can you gain enough access to remove these things in order to remove the shaft? And how the heck would you replace them when the repair is finished?
I would REALLY appreciate advice... I'm in SW Michigan, and am nervously watching the weather for signs of snow, as this machine is my only means of pushing snow on my larger-than-life driveway (400 feet plus). Or if there is anyone local (Berrien County) that is skilled at this repair, I'd be happy to reward you admirably for your help in removing the shaft and fixing the U-joints.
And believe me-- if i can get this repair complete, i'll be greasing those joints minimum once yearly, maybe even twice. I don't ever want to do this repair again!
Steve S.
/ Another 2210 U-Joint problem! #2
I just had mine done at the dealer....Two forty dollar joints and the rest labor...700 all total....OOOOuch!
He told me there was a lock type ring or c-clip and you need a long punch type of tool (18" I believe) to reach it.
To grease the front you can make a 12" straight tube adapter for your grease gun to reach from the access panel on the left side of the kick panel.
To grease the rear u-joint, the dealer made me an L shaped adapter. Much harder to reach but you can get to it from underneath.
Enter from the front of the shield and reach toward the rear joint. Note the top of the L shaped adapter had to be grounded flat to get into the tight space. The tips of the grease tube fittings may have to be grounded to get into the space of the joint. The drive shafts are at a slight angle so the grease gun fitting can only be used at these particular spots/angle. (pointing towards the left side of tractor) I found that when you shut down the tractor the u-joints always stop in the same place (zirk's pointing to the left) so be sure to note the direction the zirk fittings are pointing and replace in the same direction. I discovered this after cutting a 2" hole from the floor and attempting to reach the zirk fitting from the top. Hope this helps and good luck.... IMG_1730.JPGIMG_1731.JPGIMG_1732.JPGIMG_1726.jpg
I visited the dealer today, and they told me that the U-joints are now available separately from the shaft. $40 each. The clerk appeared surprised, previously these joints weren't available. John Deere must have heard some complaints about this problem. They'll be here Wednesday. I am hoping these replacement joints have a zerk for greasing. I also got the 2 part roll pins and C-clip. I'm going to try it... For those of you who have removed this shaft at the front joint, do you have any advice? Where best to access, tools to use, removing the c-clip, etc?
/ Another 2210 U-Joint problem! #5
Megotatractor posted this information:
I posted the story elsewhere on these forums but I had to disassemble the entire tractor; ROPS, fender, floor, cowl, and dash. Then do the ship-in-a-bottle operation through a small steel plate in the right side of the frame to release a large C-clip from the front ujoint in order to remove the driveshaft.
Then after he finished he posted this:
Now I know, to access the front u-joint remove the kick panel below the dash and a metal plate on the right side of the frame!
/ Another 2210 U-Joint problem! #6
Search replacing trans fan. I posted here or My tractor forum of how to get the front shaft off.
SUCCESS! Got the shaft removed without too much trouble. Thanks Gator6x4 for mentioning the metal plate on the right side-- it is really the only way to get the C-clip and 2 roll pins removed. I bought a set of roll pin punches, made it pretty easy-- removing the C-clip (in pieces!) was much more difficult.
There is one cup that is simply annilhilated. The joint has begun to chew into the yoke, but it appears small and isolated, I am hoping it won't affect anything once a new cup is installed. That sucker was DRY as a BONE- i wonder if Deere forgot to lube that one from the factory.
Got new joints on order, plus new pins and C-clip. For the reinstall, I am wondering if I can premount the C-clip on the yoke stub beside the slot, and then once the pins are tapped in, simply pull it so it clicks in place into the slot-- has anyone tried this?
Thanks to all for your advice, it gave me the guts to try this.
/ Another 2210 U-Joint problem! #8
Glad you got it apart, I didn't know about that metal plate. That had to make the job much easier.
/ Another 2210 U-Joint problem! #9
is there any way to easily determine whether one has excessive wear occurring short of tearing everything apart? What should I be looking for?
Finally, start to finish, how long should it take to replace the U-joints?
I discovered my problem after reading posts here. I then thought "Hey, I changed the rear joint at 300 hours, but have never even glanced at the front one, now have 632 hours." So I pulled the inspection port (near your left foot when aboard) and peered in there with a light. Mine were as loose as they could possibly be without actually breaking the yokes. It was especially apparent when I watched as I turned the engine off, or restarted it. There was a LOT of slop and rattling as metal clanked on metal. After disassembly, one yoke hole has a slight elongation, I am hopng it won't matter once the new cup is installed. Gonna watch that one closely for signs of wear.
I probably have 1.5 to 2 hours in tear down, plus 30-40 minutes in shaft removal. On the reassembly, I expect it will go a bit quicker. I'll probably leave my ROPS off until spring, as the machine will not leave the pavement until then. Don't tell OSHA. There about 12 bolts that hold the ROPS, an Impact or Air Rachet would speed this up a bit.
/ Another 2210 U-Joint problem! #11
"easily" ?? NO!! In my case at about 600 hours I started noticing a vibration. By 650 hours the vibration became a disturbing shudder. Can't hardly see the joints much less get hold of them to feel for slop. Shine a flashlight into the kick panel port and take a close look for a gap along the yoke bearings and if you see a shiny space like I did order the spider bearing kits and get busy with the wrench.
/ Another 2210 U-Joint problem! #12
Thanks both,
This is what I somewhat expected. I have 502 hours on my JD2305 and I haven't noticed anything too obvious yet though I have recently thought that overall the tractor is running a touch louder/rougher/etc, I couldn't pin point anything specific and it may just be my imagination. I was curious if the failure is sudden or something where I have should have some level of advanced warning if I'm paying attention. Steveschultt's comment regarding having to replace the rear joint at 300 hrs has me a bit concerned and I will have to do a close inspection this weekend.
Sounds like I may not be far from needing to schedule a Saturday tear-down.
Megotatractor - Besides the two spiders(LVA803335), you mentioned breaking some plastic clips(??) and bending the snap ring(40M4624?). Do you happen to remember the clip part numbers (or name) of the clips you are referring to? If I end up tearing this sucker down, I want to be stocked with whatever I may need to put it back together immediately.
/ Another 2210 U-Joint problem! #13
Thanks both,
Sorry but that is exactly what I started to notice - maybe even started to notice a year earlier than I thought- that the tractor seemed louder/rougher. In retrospect I believe that was my earliest indication that there was something wrong. AFter fixing it seemed quieter and smoother. Some posts here indicate u-joint failure as early as 300 hours.
The plastic clips that I broke or stripped out were the 4 pieces that attach the rear fenders to the back of the floorboard. M91429 unfortunately I bought them after the tractor was put back together and will have to remove the ROPS again to install them. And some of the c-clips were a bit bent from removing them from the yokes- the paint had caused them to stick and in forcing them loose I bent them.
I think the biggest challenge in disassembly is the large c-clip that retains a roll pin in the front yoke. He requires a large, sturdy c-clip pliers that will also reach into the hole -remove the metal plate from the right side of the frame after removing the kick panel- and a long pin punch. And by all means set the clip in place alonside the slot before you reinstall the driveshaft. Makes it easy to just pound the roll pin in and pop the ring into place and done!
/ Another 2210 U-Joint problem! #14
Very good info Megotatractor. Thanks for taking the time. I'm sure this will come very handy eventually. :thumbsup:
/ Another 2210 U-Joint problem! #15
Thanks both,
On a JD2305 you can see the driveshaft and both U-joints from underneath the tractor. You can even grasp the driveshaft and pull and push to see if any slop exists. You can also grease both U-joints from underneath the tractor by using a needle point injector available at most auto supply houses. If you have never greased your U-joints, from your post it sounds like you have not, I would strongly recommend this become a top priority. It may be too late, damage could have already occured. Also I think the removal and replacement of the U-joints are different.
Removal and replacement different. This posting is from MARKMEYER on another forum.
I didn't have to remove any hardware to get access other than the shaft itself, and it was quite easy.
Just slip the snap ring at the front forward, drive out the springpins (note that there are two; one inside the other), and then the shaft comes right off.
R&R the plastic fan, reverse the above, and you're done.
Probably the hardest part is to find an over long punch that has some reach to it to get to the pins. I cheated and used a gentle nudge from an impact gun to help the punch along so I wouldn't skin up my knuckles swinging a hammer under there.
The only thing I thought of changing (but didn't) was maybe replacing the pins with a grade-8 bolt and nylon insert locknut. A 6mm bolt 40mm long should do the trick and be a perfect fit. The nylon insert locknut would keep it from loosening up. If doing that, forget the snap ring because it just wouldn't be needed. On a subsequent fan change, undoing the bolt and nut would probably be much simpler and easier to get to than having to drive out the pins again.
I think the next time I have to replace the fan, I most certainly will go back with a nut and bolt.
For people doing it for the first time, I'll point out a few things to watch for:
1. I'll restate again that there are not one, but two roll pins to drive out on the front collar. I haven't yet figured out the "why" of the engineering, but if you drive out the inside one, you might think you're ready to slip the collar off... but you're not. Be sure to drive out the second (outside) pin using something around a 6mm straight punch.
Of course, the rear collar at the fan has no retention scheme whatsoever (even though the 2305 Manual suggests that there is). Just slip it forward and it's off.
2. While you're under there, take a close look at the rubber coupler at the front end that's bolted to the flywheel. It's designed to fail "gently" by the bolt sleeves sliding out, so just take a look as long as you're getting dirty.
3. There's a bearing inside a cup that is inside that rubber couple. If your tractor is low time, the bearing is probably in fine shape. But if you have lots of hours on your tractor, it's not that hard to unbolt the coupler from the flywheel and remove and inspect the bearing for smooth operation. A new one is only $6 (greenfarmparts) so if you doubt the condition of the bearing at all, just slip in a new one.
4. By the way, don't even think of smacking the driveshaft where the spider bearings are to knock it off. There should be no reason to force it all, and if you must, spray some WD40 on both ends of the shaft to loosen it up if it's a little "rusty stuck". A gentle tap is all you should need (if at all). While doing this, do not forget that the shaft assemble ONLY comes as an assembly, so if you knock one of the bearing cup holders out of whack, it won't last long before the bearing is destroyed and you'll need a new shaft assembly (somewhere around $550 or so... I checked).
5. You don't have to remove the gold crossbar just in front of the fan to install it, but you of course have to loosen the two fan shield bolts and slip the shield off (just loosen those bolts because the fan shield attach points are slotted).
The fan's blades are very flexible, so what you do is slip it up from behind the crossbar at an angle, bend the blades at the top back a little to clear the underside of the floorboard until the shaft hole of the fan just slips over the shaft. You'll have to bend the blades at the bottom a little as well where they contact the gold crossbar. That's it, you're on.
6. Naturally, grease the spiders on both ends of the shaft while it's out.
I'd like to make it sound more difficult but I can't. If it takes you more than an hour or so to change out the fan, then you're drinking too much beer during the process. With the beer and chatting with friends and changing out the music CD's, it took me about 3 hours this first time.
I might take 4 hours the next time I do it because I ran out of beer this time way too early.
I completed the reassembly today (except the ROPs) and fired up my 2210 with fresh U-joints. It felt like VELVET! Much smoother than it's been in the past months. Can really feel the difference.
Thanks for all the tips. I also cut a neat new access hole in floorboard as suggested in another thread, perfectly matching the access plug from the kick panel. Ready to grease at next service. And soon, will be ready to plow.
/ Another 2210 U-Joint problem! #17
View attachment 291390View attachment 291391View attachment 291392
Yep, my '03 2210 had failed driveshaft bearings at around 700 hours. There was nothing left of the bearings but a reddish powder! I have yet to find a way to grease the rear u joint even after cutting a hole in the floorboard so I have a feeling that in the next couple years I'm going to have to dissassemble the whole thing again! Now at over 900 hours.
As for re-installing the C clip, I recall doing it exactly as you describe.
and...
HAS ANYONE FOUND A GREASE GUN TIP THAT FITS INSIDE THESE YOKES????? I CANNOT BELIEVE THAT THERE ISN'T SOMETHING OUT THERE!
Just worked on this again, 3 years after changing the Ujoint. Have tried different fittings, needles, and tips, and just couldn't get any grease in there. Finally had success- took a grease gun tip, and ground the tip way down, made it pretty slender. Was finally able to pump some grease in those joints. Difficult to work through those small access panels while squatting & bending. But it sure feels good knowing I pumped some grease in there.
/ Another 2210 U-Joint problem! #19
2004 Johnson 40hp 4-Stroke Outboard Boat Motor (A66738)
2004 Johnson 40hp...
2008 FORD F-350 UTILITY BODY (A66091)
2008 FORD F-350...
2018 RAM 3500 4X2 S/A DUALLY TRUCK (A69167)
2018 RAM 3500 4X2...
2011 Hyundai Sonata Sedan (A66738)
2011 Hyundai...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
Thompson Water Pump Diesel Engine (A66734)
Thompson Water...
