Aftermarket Toplink holder...
/ Aftermarket Toplink holder... #1
Buckgnarly
West topsham VT
Kioti DS3510
After my "wife" bent the OEM Kioti toplink when raising the rear weight, I had to get a *gasp* JD toplink (closest dealer to me)....well, the ends are larger ID (stronger) but will not fit in the OEM Kioti top link holder. To resolve this, I welded a half chain link to the body of the top link which conveniently doubled as a chain holder for the PTO shaft cover! Pics...
/ Aftermarket Toplink holder... #2
Clever and thank you. I think I am going to use your idea.
/ Aftermarket Toplink holder... #3
Still trying to find a holder for my Fit-Right hydraulic top link.
/ Aftermarket Toplink holder... #4
You could use a link of chain, run a hose clamp through the link, tighten it up around the cylinder in the proper place so as that the OEM retainer would hook onto the link. Simple and inexpensive. ;)
/ Aftermarket Toplink holder... #5
Don't want it to look like a Fred Sanford special. using a tie down strap now.
/ Aftermarket Toplink holder... #6
By chance if you were to twist the OEM holder hook 90 degrees, would that then latch onto the hydraulic port? That is what I did for my 3215 and it is about perfect.
/ Aftermarket Toplink holder... #7
I tried to bend it, no go
/ Aftermarket Toplink holder... #8
That actually looks like a BE (Braber Equipment) top link, the Deere top links are painted black and have handles bent on either side for adjustment vs/ the single rod through middle of the cylinder. Very clever idea for the top link holder, I like your thinking. :thumbsup:
/ Aftermarket Toplink holder... #9
I have an old JD top link that had a rod thru it for adjustment. I took the rod out and put the hook in the hole, works good and stays there. Just drilling a hole about 5/16" might help you out.
/ Aftermarket Toplink holder... #10
I went to Home Depot. Got a length of 1/4" zinc plated rod. With a hammer and a vise I bent into shape. I even slid a piece of clear 3/8 tubing on the hook end to keep it from scratching the top link cylinder. Then I mounted it where the original was. You can see the original and larger toplink holder I made in the pic.
/ Aftermarket Toplink holder... #11
HEY BUCK what are you using for a rear counter weight ? and did you fill the rear tires ??
getting my Ls today will post pictures as soon as it gets here ...
jeff
jeff
For FEL work, I have a barrel filled with concrete, about 400lb or so. Rears are filled with washer fluid, not sure on weight on that though, never crunched the numbers.
We will need pics!....
/ Aftermarket Toplink holder... #14
conveniently doubled as a chain holder for the PTO shaft cover! .
If it were me, I'd find somewhere on the attachment frame to clip the PTO chain -- I'm way too lazy (uh, efficient) to have to deal with it every time I change equipment. If you set the length right, it will also keep the end of the shaft from touching the ground when unhooked.
/ Aftermarket Toplink holder... #15
as requested pictures here
PICTURES OF MY NEW LS R3039H
also would like pictures of how you did your barrel for counter weight
Jeff
