Aftermarket Toplink holder...
/ Aftermarket Toplink holder... #1
Buckgnarly
West topsham VT
Kioti DS3510
After my "wife" bent the OEM Kioti toplink when raising the rear weight, I had to get a *gasp* JD toplink (closest dealer to me)....well, the ends are larger ID (stronger) but will not fit in the OEM Kioti top link holder. To resolve this, I welded a half chain link to the body of the top link which conveniently doubled as a chain holder for the PTO shaft cover! Pics...
/ Aftermarket Toplink holder... #2
Clever and thank you. I think I am going to use your idea.
/ Aftermarket Toplink holder... #3
Still trying to find a holder for my Fit-Right hydraulic top link.
/ Aftermarket Toplink holder... #4
You could use a link of chain, run a hose clamp through the link, tighten it up around the cylinder in the proper place so as that the OEM retainer would hook onto the link. Simple and inexpensive. ;)
/ Aftermarket Toplink holder... #5
Don't want it to look like a Fred Sanford special. using a tie down strap now.
/ Aftermarket Toplink holder... #6
By chance if you were to twist the OEM holder hook 90 degrees, would that then latch onto the hydraulic port? That is what I did for my 3215 and it is about perfect.
/ Aftermarket Toplink holder... #7
I tried to bend it, no go
/ Aftermarket Toplink holder... #8
That actually looks like a BE (Braber Equipment) top link, the Deere top links are painted black and have handles bent on either side for adjustment vs/ the single rod through middle of the cylinder. Very clever idea for the top link holder, I like your thinking. :thumbsup:
/ Aftermarket Toplink holder... #9
I have an old JD top link that had a rod thru it for adjustment. I took the rod out and put the hook in the hole, works good and stays there. Just drilling a hole about 5/16" might help you out.
/ Aftermarket Toplink holder... #10
I went to Home Depot. Got a length of 1/4" zinc plated rod. With a hammer and a vise I bent into shape. I even slid a piece of clear 3/8 tubing on the hook end to keep it from scratching the top link cylinder. Then I mounted it where the original was. You can see the original and larger toplink holder I made in the pic.
/ Aftermarket Toplink holder... #11
HEY BUCK what are you using for a rear counter weight ? and did you fill the rear tires ??
getting my Ls today will post pictures as soon as it gets here ...
jeff
jeff
For FEL work, I have a barrel filled with concrete, about 400lb or so. Rears are filled with washer fluid, not sure on weight on that though, never crunched the numbers.
We will need pics!....
/ Aftermarket Toplink holder... #14
conveniently doubled as a chain holder for the PTO shaft cover! .
If it were me, I'd find somewhere on the attachment frame to clip the PTO chain -- I'm way too lazy (uh, efficient) to have to deal with it every time I change equipment. If you set the length right, it will also keep the end of the shaft from touching the ground when unhooked.
/ Aftermarket Toplink holder... #15
as requested pictures here
PICTURES OF MY NEW LS R3039H
also would like pictures of how you did your barrel for counter weight
Jeff
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A64556)
2018 Nissan Titan...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
2018 Ver-Mac S/A Solar Towable Speed Trailer (A64194)
2018 Ver-Mac S/A...
2009 IC Corporation PB105 School Bus (A64194)
2009 IC...
