BH Stabilizer Holder
/ BH Stabilizer Holder #1
Mac in PA
Somewhere North of the Mason Dixon Line
Kubota L 3800, Austin Western Pacer 100
Ok, so I don't have a good name for it.
In order to make more room in the garage I park the tractor with the wheels almost against the wall. This is OK for a few days but after a week or more the stabilizers drift down against the wall. Not good for drywall.
After some extensive thought and careful engineering (and a beer or two), I came up with a solution. I used a chain and welded a bolt on each end so it can be attached between the stabilizers preventing drift down.
Of course the proper color paint was also required. :D
/ BH Stabilizer Holder #4
Looks much better than the ratchet strap that I use for my BH stabilizers.
I don't use my tractor much, but the stabilizers do not drift. Guess that's good.
Mine didn't drift either when it was new.
The seals in your cylinders are probably still tight on the rod and in the cylinder bore to cause enough friction to prevent drift.
Mac
/ BH Stabilizer Holder #8
I use a ratchet strap but I do like your solution. :thumbsup:
/ BH Stabilizer Holder #9
Ratchet strap is how I do it. works great. Leave it a little loose when you put it on so that when you start up all you need to do is raise the stabilizers all the way up and just slide the hooks off, no adjusting or fussing. then just rehook when all the way up and let the hydro's relax and the strap stops it after an inch of movement. Oh yes i have thought this out. Simple and quick.
/ BH Stabilizer Holder #10
Mine didn't sag when new but now with only 70 hrs they'll droop several inches in a couple days. The more annoying part is that when I remove the BH, there is enough sag that unless I block up the frame, it will drop to the ground in a few hours and then the hoses are fiddle tight to reconnect to raise and remount it.
To me, ZERO sag is acceptable. Over the entire winter maybe, over night or a week, it shouldn't move at all. I'm trying to get answers from my dealer as to just how much sag is acceptable by Kubota
/ BH Stabilizer Holder #11
I welded one link of chain on each pad.
Then and ratchet strap between them like lots of others.
Deere 644K (A62180)
Deere 644K (A62180)
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
2018 HINO 258A REEFER TRUCK (A63569)
2018 HINO 258A...
2021 Komatsu WA270 (A62180)
2021 Komatsu WA270...
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
2020 Doosan DX35 (A62180)
2020 Doosan DX35...
