What motor lasts longer
/ What motor lasts longer #21
Everything being equal what motor will last the longest, Diesel or gas???
To paraphrase a past Pres, all depends upon what the definition of equal is. :) Both designs can be made with same reliability/durability. Typ diesel engine is designed for industrial like service while the typ gasoline engine is designed for automotive service. Do you think the typ diesel that weights about twice a typ gas engine has no affect on it's durability? Remember the few diesels that were offer in some auto and were based on gas engine designs/blocks and internal parts and weren't all that successful? How often do you see a "gas" engine who's internal parts are as massive as typ seen in a diesel of the same displacement?
Intended for the same service, either design can be made to yield similar reliability/durability.
But maybe your definition of equal is something different.
/ What motor lasts longer #22
For comparison purposes, can we compare a 3000 Ford Diesel Tractor and a 3000 Ford gas Tractor. Same year model with same daily work duties in the same climate, I pick the 3000 Diesel. Ken Sweet
/ What motor lasts longer #23
Good call:thumbsup::thumbsup:
Remember them first GM 350 ? Diesel cars?:D
/ What motor lasts longer #24
Neither will last very long without adequate maintenance...that being said, diesels are necessarilly built heavier as the compression ratios are close to 3 times what a normally asirpated gasoline engine are..ie. Maintenance intervals on diesels are much more important ...if you've ever had to replace a piston/and an injector on a Detroit 6-71, you'd understand. Let's start with a small crane...BobG in VA
/ What motor lasts longer #25
I have some experience in this issue in boat motors, and since they are used in a constant heavy load, i.e. pushing water isn't easy, there is a huge difference in longevity. A gas motor, say a big block GM which is most common, assuming its auxiliary equipment like pumps don't fail, which they always do, will last somewhere between 1000 and 2000 hours before a complete rebuild. Diesel engines taken care of will go 7-10,000 hours; in constant daily use, and if run properly, two or three times that. The biggest problem is lack of use; daily operators like fishing boats or ferrys get huge hours out of their engines. Let an engine sit, and corrode from salt air, and good luck.
Also, once you get past about 400 hp, the question is moot; there aren't any gas motors putting out more than that, so from there up, the only option is diesel.
A true truck gas motor, like a Ford V-10, will likely run a long, long time if the cooling system is maintained.
But in an apples to apples comparison, I'd say diesel without question. Lower rpm and typically heavier construction.
Look how many large diesel tractors are sold at the 6000-7000 hour time. That seems to be an industry standard it is so common place.
/ What motor lasts longer #26
Not a chance. Diesel x2 if not 3
/ What motor lasts longer #27
I think the only area where there might be a convergence of the life of a diesel and gas engine is in light trucks and autos. In that market gas engines are doing better each year and diesel engines are often not heavy duty models that are tried tnd true. Put any real load on the engine and "real" diesels last way longer.
/ What motor lasts longer #28
IMO/Experience a diesel will outlast a petrol (all being equal & in similar applications) easy 2 or more times....generally vehicle utes (i.e pick ups) also support this view unless the diesel has been built to a price?r the diesel is being used at high varing RPMS outside it's performance/design parameters &/or with many low idle RPM/lightly loaded appications....And the restrictive & hotter running Tier IV/V diesels will erode the durabilty "gap".
As to inline diesels being more durable than V's? It makes no difference in our experience & can quote many examples as below:
We have a old c. 400hp Steiger CP1400 tractor at 29,000 hrs (yes 29,000hrs), the Cat 3306 inline still purrs away using no oil & no reason to think anything is going to fail anytime soon .......we also have a c.400 hp 1982 Acremaster tractor at 36,000hrs (yes 36,000hrs) the V Mercedes engine is still fine - both engines are OEM fitment without rebuilds.
Given good maintenance history, use of premium lubricants, an adequate cooling system & clean air/fuel -the petrol engine durability will be influenced poorly by ethanol fuel use & the diesel engine similarly by the use of ULSD (Ultra Low Sulphur Diesel- since 2006 almost all the European/Nth American fuel is ULSD) or biodiesel, in "non-electronic" gear such as these old tractors & non road registered equipment we use a mix of 70% diesel/30% waste oil (engine & hyd oil filtered by a centrifuge, then pressurised through static filter mediums) to better preserve engine life (& save a few $$$$'s in fuel costs )
/ What motor lasts longer #29
So you're saying that the ULSD is a poor choice of fuel? Interesting, because I was recently told the opposite. I'm not saying you're right or wrong, just wish I could see some facts that would support either side of the argument.
/ What motor lasts longer #30
yup.
64 and older..... i'll take gas... 65+ I'll take diesel.. :)
/ What motor lasts longer #31
Hmmm. I wonder if a closer comparison might come from Europe where the proportion of diesel automobiles is very high. The uses of these vehicles would be very similar, so a comparison of maintenance and/or lifespan would be closer to an apples-to-apples comparison.
Now the question is, "does anybody have these data for Europe?"
BOB
/ What motor lasts longer #32
Seems this discussion has taken two paths. I took the original post as more of a theoretical question and that's how I addressed it. The other path appears to be more of a comparison between typ commercially available engines which in my opinion are not apples to apples comparison, equals.
There are in the past and today examples of large industrial gas (spark ignition) engines that can and do stand toe to toe with diesel engines. Here is an example (see pic) of what is available today. Low speed, 1400-1800 rpm designed to run 24/7. Over in Salt Lake City they try and manage the lakes level by pumping water in/out. There are three I believe, gas powered engines driving pumps, large ones, ones that pump 450,000 gpm, yes per min. Think this project would use gas powered engines if reliability/dependability were not up to the task? With some applications, fuel availability dictates engine design, compression Vs spark, not reliability/durability considerations.
I have no problem if you take the path of comparing engine types if you want to compare what's available down at your local car/tractor dealer but the original question said all else being equal. I think the GE Waukesha engine is an example of a gas engine that is equal.
/ What motor lasts longer #33
Those are engines.
/ What motor lasts longer #34
Are those Waukeshaw engines running on natural gas?:D
There are many two and four cycle industrial engines running on natural gas 24-7 - 365 days a year.:)
/ What motor lasts longer #35
I am not really sure how you are comparing apples to apples. You talk about 3 large gas engines running 24/7, but what are you comparing them to? If you had two comparable engines, one gas and one diesel, running 24/7 side by side, and one outlasted the other, that would be another story. But just to say that you know of 3 gas engines that run 24/7, doesn't prove that gas will outlast diesel. It actually doesn't prove anything. Then to say that this project wouldn't have used gas engines if they weren't reliable and dependable, well thats just your opinion. There are a number of reasons why they may have gone with gas engines, budget could have been one of them. Lastly you keep bringing up reliability and dependability. No one is saying that gas engines aren't reliable or dependable, they most certainly are. The title of this thread is "What motor lasts longer"
/ What motor lasts longer #36
It would be hard to imagine that large a "gas" engine not being powered by "gas" and I don't mean gasoline. How could the economies work out otherwise? Diesel and Gasoline are distributed widely. But if LNG prices are especially low locally, a non-gasoline powered "gas" engine usually lasts much longer and could possibly directly compete with a diesel plant.
But I think the answer lies with rpm. And at what rpm...900 rpm ship engines last amazingly long, though they usually have quality planned long term maintenance.
Now what gasoline powered engine is going to produce full output at 900 rpm, or say to a max 1000 rpm spec? I can't think of any. Most of what I've seen is that the lower the rpm, the larger the engine is relative to output. Which adds to cost. But they last longer and are now as likely to be running the main generator for a giant electric boat as they are hooked to a propeller. Likely those Waukeshaws were running at 1200 or 1800 rpm max pumping water, which is full design load. Lastly, and never lastly is cost and budget. But I think there are ways of comparing dollars per horsepower or pound feet of torque. Ultimately, I think the answer to this question is the motor that runs at the slowest speed is likely to last the longest.
It's all just generalization unless you have a good spec. The wider the spec the more possibilities, and comparison becomes less accurate. But it does allow us to prattle on...
/ What motor lasts longer #37
If you compare it "fair" lb for lb engine material weight, and same wok done compare a 2 stoke gas to diesel.
Take a quality gas 2 stroke like a husky, or Stihl chainsaw engine where the engine alone weighs about 5lb, but can make 3-5hp for 2,000 hours. It would be atough challange for a 5lb diesel to make that kind of power for so many hours...
/ What motor lasts longer #38
that reminds me of a 4" trash pump we had.. it had a pull start diesel engine.. was cantankerous.. but worked. havn't seen too many small 'lawnmower engine' sized diesels like that...
/ What motor lasts longer #40
There's lot of speculation around ULSD, the facts are hidden & manipulated to support either perspective (Ditto fgor biofuels).
IMO ULSD is not the best choice of fuel for overall engine longevity - sulphur compounds are a natural lubricant for fuel pumps/injectors, hydrofining to remove the sulphur &/or using low sulphur crude means the oil company's are substituting less effective additives/detergents (ever noticed the extra foaming of ULSD ?) as poor lubricants to meet minimum lubrication standards (which high sulphurs diesel substantially exceeded), there have also been changes in the cloud point, distillation & cetane content coninciding with the intro of ULSD globally in developed markets - The initial noticeable "impact" of ULSD is in on fuel pump seals which now degrade exceeding quickly c.5yrs & less in older gear, those with older tractors with CAV type pumps may experience increased oil consumption as the shaft seal linking the pump to the crankcase degrades...
Bio fuels (diesel & enthanol) don't sustain prior engine durability experience either, primarily as they're hygroscopic & readily absorb water & have different lubrication/catalytic properties than the fuels they're replacing- potentially unless the bio fuels are dried correctly, stored in closed environments & used within a reasonable period of time all sorts of drama/wear/contaminates can result.
The other concern with BioDiesel is by absorbing water it actually promotes the growth of algae in diesel tanks....again causing all sorts of drama.
How did I come to the conclusion of what's best for our operation? We engaged a specialist fuel engineering company to analyse & make recommendations (at a cost of $60K+)., I too have been tempted by Biofuels as use across our Truck, Farm & Earthmoving fleet & was even contemplating installing a Biodiesel plant (extremely cost effective growing/using our oil seed cropping), as just buying Biodiesel would have saved conservatively $17K+/yr in fuel costs, with a self managed plant exponetially more ..........
I elected the risks far outway any running cost benefit & though also forced down the ULSD path because of what's commercial available, on the advice of our consultants supplement with our own enhanced additives on the non road registered equipment which is not subject to emissions legislation to hopefully compensate for the lack of sulphur ........others may have a diffferent view & make other choices....
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
2021 Felling 29FT FT-45-2LP Trailer (A64194)
2021 Felling 29FT...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
