Mid-mount... blower? Does such an animal exist?
/ Mid-mount... blower? Does such an animal exist? #1
Ken73
Sealy, TX
Kubota BX25
Not a snow blower - I'm so far south that we almost never see snow. (Once in ten years is a LOT.)
I'm thinking more along the lines of a giant leaf blower under the belly. I've got a metric buttload of acorns from all my oaks this year and a little handheld won't cut it. That and the leaves will be a nightmare soon enough.
/ Mid-mount... blower? Does such an animal exist? #2
Never seen a belly mount leaf blower. Have seen three point, but they are expensive. The three point take a lot of horse power, but will move leave and acrons. Dangerous to be in front of when in operation. I am sure if a mid mount is available Ted will know. Tractor 3 Point Hitch & Pull Type AgriMetal Blowers, PTO Driven and Gasoline Engine Powered
/ Mid-mount... blower? Does such an animal exist? #3
/ Mid-mount... blower? Does such an animal exist? #4
I have seen a sweeper for the front. I doubt it would be cheap since you would have to buy the sub frame, the PTO kit, and the sweeper.
/ Mid-mount... blower? Does such an animal exist? #6
A cheap alternative would be one of the pull behind sweepers.If your ground is flat they work pretty good at picking up acorns,nuts and sweet gum balls.
Lawn Sweeper | QC Supply
/ Mid-mount... blower? Does such an animal exist? #7
A sweeper would be the ideal tool, but are relatively expensive.
I was thinking mid-mount so it'd be out of the way; that and I could have my finish mower on the back and be able to blow the crud off the driveway with it (or leaves for that matter) without having to detach/reattach the mower.
/ Mid-mount... blower? Does such an animal exist? #10
Might be able to mount a 3 point one on the front and use a 4-1 reducer to drop the 2000RPM mid PTO to 540ish, but it would not be cheap.
Aaron Z
/ Mid-mount... blower? Does such an animal exist? #11
I have the grass collector with MMM powered blower on my 60" MMM. I do not use it to collect grass but it will chop up and collect lots of leaves before it must be emptied.
Yes, you must remove any three point mounted implement to use it, as the grass collector mounts behind the tractor.
Dean
/ Mid-mount... blower? Does such an animal exist? #12
Hmmm. I wonder if you got a MMM and modified it so it had blades that were bent 90 deg so they are running vertical instead of horizontal like usual for a mower. Then you have created a centrifugal fan. How well it works...dunno. Would probably want to modify the output chute to direct it better, and possibly enclose the bottom with some sheet metal (leaving an opening in the center for air inlet). If you have a mid PTO and can find a mower to modify that is old and abused, it might be worth a try...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
TANK MANIFOLD (A58216)
2006 John Deere 35D Excavator (A63109)
2006 John Deere...
2024 John Deere 835M Gator (A63116)
2024 John Deere...
2015 BIG TEX 22GN -32 GOOSENECK (A63569)
2015 BIG TEX 22GN...
3015 (A56857)
3015 (A56857)
