LA481 Quick Attach
/ LA481 Quick Attach #1
kevincook
k
Hi Everyone,
Does anyone know if Kubota makes a quick attach for my old loader, LA481 on my L3010?
I'm thinking of adding a skid steer type quick attach. I'm not even sure if it was available as an option when I bought the machine.
Thanks,
Kevin
/ LA481 Quick Attach #3
kevincook said:
Hi Everyone,
Thanks,
Kevin
I put a quick attach on my B3030 loader. Dealer tried to warn me against it, but I did it anyway. It distorted the geometry of the loader since it wasn't made for a QA front. I was unable to raise the front end off the ground and didn't have the power I thought the fel should have. Took off the attachment and put in factory bucket And all was well. The attachment changed geometry of front end and skid steer front bucket was heavier than the factory bucket.
/ LA481 Quick Attach #4
Hello Kevin...
You will like the Kasco Unihitch.
It will allow any Skid Steer attachment that your tractor can handle... My local Kubota dealer sold me one for my loader. Uni-Hitch | Kasco Manufacturing Co., Inc.
KennyV
Forgot to mention .... That was about 10 years ago... I Only use Skid Steer attachments & have a lot of them... you will always be able to lift what your loader was designed to lift... KennyV
/ LA481 Quick Attach #5
We offer a custom built quick attach adapter for your loader. The drawings are on file so you will not need to provide us with any measurements. They ship free to your home within 1,000 miles of Newton, NC. I hope this helps.
/ LA481 Quick Attach #6
That will add weight and move it farther out. Both reduce the actual lift capacity of the machine. You can change the cylinders to 2" or 2.25 to regain the capacity, but that will stress the frame, etc and will add $$ to the project.
Wish it were different, as I have that same loader on a 3410.
43023 (A59228)
43023 (A59228)
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
2017 Ram 5500 Bucket Truck (A63118)
2017 Ram 5500...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
