add-a-circuit kit for LED lights
/ add-a-circuit kit for LED lights #1
kubotacory
Shermans Dale, PA
Kubota B7800
Does anyone have experience/issues with using an Add-A-Circuit kit for additional wiring on your tractor? I have a Kubota B7800 with the dynamo instead of the alternator and want to add work lights. I've taken in to consideration that the dynamo only produces approx. 14 amps and with that have decided to spend the extra $$ and go LED work lights. I plan to replace my current headlight bulbs with LED's as well to free up space, perhaps some taillights too if need be. I'm looking to put four 18W work lights on one circuit with a total of 4.24 Amps draw. I also want to have the lights powered from a switch so figured it best to keep them on their own circuit rather than splicing into an existing. A thought was to use one of the ATO Add-A-Circuit kits to tap into an existing fuse slot. Can anybody provide any advise on this?
/ add-a-circuit kit for LED lights #2
Re: add-a-circuit
Does anyone have experience/issues with using an Add-A-Circuit kit for additional wiring on your tractor? I have a Kubota B7800 with the dynamo instead of the alternator and want to add work lights. I've taken in to consideration that the dynamo only produces approx. 14 amps and with that have decided to spend the extra $$ and go LED work lights. I plan to replace my current headlight bulbs with LED's as well to free up space, perhaps some taillights too if need be. I'm looking to put four 18W work lights on one circuit with a total of 4.24 Amps draw. A thought was to use one of the ATO Add-A-Circuit kits to tap into an existing fuse slot. Can anybody provide any advise on this?
Not only do I not have any experience with it, I have some reservations with it. A fuse is to protect the wiring from and overload that would raise the temperature of the wire and lead to a fire. So for a given wire size in the harness there is an applicable fuse size that will overheat and open the fuze element before the wire overheats. I am thinking that the manufacture puts that size fuze in the slot to begin with. Now if you put an add on device like this on AND if you put two fuzes in it that are the same rating of the original fuze than you are going to be in trouble. Now if you had an original 10 amp fuse lets say and you put this device on and stocked it with two 5 amp fuzes in it to have 2 circuits that are fuzed at 5 amps each, then I would say you would be OK.. My point is do not exceed the original current draw that was spec'd for the wiring harness. I applaud your idea of replacing the incandescent bulbs with LED's especially given your low generating ability.
James K0UA
/ add-a-circuit kit for LED lights #3
I looked up a datasheet on one of these. This particular one is from Littlefuse:
"Extension board for an additional fuse protected tap from an
existing MINI size socket. The 2 fuses for the existing and the
new circuit are oriented horizontally."
It looks like one fuse is for the original circuit. The other fuse is for the added circuit and is fused independent of the original.
Edit: Forgot to add that the maximum fuse rating on this one is 10 amp.
Re: add-a-circuit
Thanks James. I understand the point of not exceeding the original current draw specified for the circuit. Until a few days ago I was unaware that these add-a-circuit kits existed and I haven't had much luck finding detailed instructions on their usage. I was surprised that the little 1156 existing incandescent headlight bulbs draw 2.1 amps each. The replacement 1156 LED 360 degree bulbs I found only draw a mere 290 mAmps each - big difference. I haven't pulled any of the tail light bulbs out to see what they are yet but figured if I replace more bulbs with LED I could possible free up enough on an existing circuit to utilize the add-a-circuit without any fears of overloading. My existing set up has a 20A blade fuse for work light. I haven't tested it all yet but I believe this 20A currently powers the rear lights (tail, turn signals, hazards) with an optional tail for an add on. I thought about just using the provided tail but not sure I could put my work lights on a switch at the instrument panel as desired.
Re: add-a-circuit
Thanks Chris. I found that same datasheet from Littelfuse before posting here. I would need the ATO style vs. the MINI style but the maximum fuse rating is the same, 10 amp. I thought too that the added circuit would be independent. I'm not entirely familiar with wiring on 12V systems so I didn't want to make wrong assumptions and mess up an existing circuit.
/ add-a-circuit kit for LED lights #6
There should be an extra unused "work light" circuit with wiring that runs to the right rear fender. It will have its own slot in the fuse box already. At least that's the case on my B2920.
Attached is the diagram for the B7800. It has a work light circuit which may be unused. I haven't tested it yet, but suppose I need to.
Like most things I tend to do, I'm probably over thinking this whole wiring scheme. I just want to do it right the first time.
Thanks for everybody's helpful advise. I picked up a new continuity tester on my way home from work today (old one broke). It appears the existing 20A work light fuse is unused so the add-a-circuit is not needed after all. The wiring for this that runs to the rear fender appeared to be pigtailed in with the tail light circuit which confused me. I bought my tractor used so not sure if that's how it came factory or if wires were re-bundled at some point. Good thing is I do have an easy tap in source on a dedicated unused circuit. Now it appears to be just a matter of where to best locate a switch, and replacing some other bulbs with LED's to keep the overall amp draw at a minimum.
/ add-a-circuit kit for LED lights #10
Sounds like you are well on your way. Good luck with the install.
James K0UA
/ add-a-circuit kit for LED lights #11
Your amp draw is insignificant here, even with just a dynamo...........wouldn't worry about it.
Remember you are not running 1-2 rad fans, blower motor, radio, lights, computer.......etc.........as you would in an auto, and certainly not for an extended period of time.
You'll be fine.
For add-on lights I make up my own wire harnesses. In my truck for example I have a separate harness for my head lights, I use the factory light circuit as a trigger only..........same with driving lights and E-fan.
/ add-a-circuit kit for LED lights #13
If you want the most of your electrical system-
Clean ALL your grounds and connections.
Replace your main cables. Use COPPER lugs and solder-fill your lugs on the cables.
Move and or add ground cables.......add new (additional) ground to dash.........move ground close to starter on engine block.
I use nothing less than 12g wire for lighting and other circuits (except trigger wire......16g is fine). Keep relays near the battery and wires short as possible. Solder and heat-shrink all wire splices.
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
Stone CP13 Asphalt Roller (A64047)
Stone CP13 Asphalt...
JCT Skid Steer Tree Puller (A64047)
JCT Skid Steer...
WESTENDORF 12' LANDSCAPER BOX GRADER (A63291)
WESTENDORF 12'...
HEIN-WERNER TIRE/WHEEL INSTALLER/REMOVER (A63569)
HEIN-WERNER...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
