TG1860 losing drive
/ TG1860 losing drive #1
Rickyj66
Hi I own a diesel TG1860 that had been put down for a while. I've just got it going again but it seems to be losing the drive. It's getting slower and slower. I changed the drive belt but it doesn't seem to help. Is there an adjustment that can be made? I see
that I can adjust the rod from the pedal to the link for the transmission
Thanks
Ricky
/ TG1860 losing drive #2
I have a TG1860G, (gas) but HST end of it will be the same.
You should not need to adjust the rod on the pedal link... unless it has been mis-adjusted.
If it's getting progressively slower, I'd suspect an HST issue. (not belt or linkage)
Has the HST fluid been changed ? Have you checked the level ?
Might be an idea to change the fluid, and purge the system.
There is a procedure in the WSM with regard to purging air from the HST following fluid change.
Pete
Thanks Pete, This TG1860 was handed down form my father in law and I can guarantee the transmission
oil has never been changed. I'll try changing the HST fluid. Is there a recommended HST fluid to use?
Ricky
Pete
/ TG1860 losing drive #4
Kubota says use 20W50 motor oil. I've changed mine using 20W50 two times in the 14 years (900 hrs) I've had mine. Never had a HST issue with my unit.
Pete
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2022 CATERPILLAR 259D3 SKID STEER (A64279)
2022 CATERPILLAR...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59910)
2019 ISUZU NPR 4X2...
BUSH HOG DITCH BANK MOWER (A63745)
BUSH HOG DITCH...
2008 New Holland T2420 (A62177)
2008 New Holland...
