Snow Equipment Buying/Pricing front mount snowblower
/ front mount snowblower #1
gravelman
NH
Kubota 2650
i just installed a front pto and 3 pt hitch on my Massey 1652 called Frontlink...it is awesome no more backing up if i get prolonged snowplowing duties....work for my town. anyone interested let me know and i can share pics etc. Gravelman
/ front mount snowblower #2
Of course we're interested. Post away!
/ front mount snowblower #3
Welcome to the forum. Yes we would love to see pics. I am interested on how it works.
/ front mount snowblower #7
Do you have to remove the hitch and pto in order to use a FEL?
quick hitch 004.jpgThe best way i can describe it is for all of you to go to www.zuidberg.com It is a 3 pt hitch and front mount pto. Cost me about $11,000. but i can tell you it is a very very rugged piece of gear. i will try to include some pictures of my setup but their website describes it best. I plow for my municipality and two years ago...snowblowed several miles of road...widening 5 weeks, 7 days a week BACKING UP No more of that. The up and down i contolled bu the bucket hydraulics and the chute turn control is also controlled by the bucket roll out, roll in control stick. It is a very slick setup but i certainly would not recommend the expense if you do little blowing... in my situation, it is well worth it.quick hitch 001.jpg For general plowing i use the rear blower and a power angle plow on the front of the loader with my quick attach connection. If im going to switch over to the front pto, i dorp the bucket and use the frontlink system. Hope this helps. Now all i need is SNOW and lots of it.
/ front mount snowblower #9
View attachment 289297The best way i can describe it is for all of you to go to www.zuidberg.com It is a 3 pt hitch and front mount pto. Cost me about $11,000. but i can tell you it is a very very rugged piece of gear. i will try to include some pictures of my setup but their website describes it best. I plow for my municipality and two years ago...snowblowed several miles of road...widening 5 weeks, 7 days a week BACKING UP No more of that. The up and down i contolled bu the bucket hydraulics and the chute turn control is also controlled by the bucket roll out, roll in control stick. It is a very slick setup but i certainly would not recommend the expense if you do little blowing... in my situation, it is well worth it.View attachment 289296 For general plowing i use the rear blower and a power angle plow on the front of the loader with my quick attach connection. If im going to switch over to the front pto, i dorp the bucket and use the frontlink system. Hope this helps. Now all i need is SNOW and lots of it.
That looks pretty sweet. Make sure to post some video footage in action if you have the means to do so. If I ever hit the lotto I'd buy a New Holland Powerstar or something similar and equip it with a front 3 point and PTO so that I could run a blower such as you've done. It looks like a really great setup.
/ front mount snowblower #11
In a lot of ways it's like my Deere hitch. The front arms even disconnect at the same spot. Because of this the loader can be attached with 90% of the hitch still left on the tractor. I also like how they use 2 hydraulic cylinders instead of one, very well built!
/ front mount snowblower #12
Nice set up. How long was the install time for hooking the system up? And when you switch from FEL to Zuidberg , approx how long to do that?
nice lineup of equipment and yes, i will take some vid... good luck, nice to hear from you
id like to know more about yours too...is it pto driven???
/ front mount snowblower #15
Me gravelman?
If so yes, the Deere units are pto driven. This unit comes from the mid pto and not the rear pto. From the mid pto there is a long driveshaft that goes to a front cage that houses two bearrings. It then, goes throught those two via another shaft and onto the blower. There are controls (a lever) inside the cab that allows for three different positions. 1) Rear pto 2) mid mt. pto and 3) rear/mid together. I guesing # 3 would come in handy if you wanted to run a rear mounter sander/salter while blowing snow.
/ front mount snowblower #16
Illustration in order. From mid pto to the blower.
ok, thanks very much...i would say that was alot lesss expensive and easier to install than my unit...good luck with it..keep in touch
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2019 ASV RT-25...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
2022 EZ-GO ELITE...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2000 Ford Windstar Van (A61574)
2000 Ford Windstar...
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
