CK20 tool box
/ CK20 tool box #1
tnmike
Gold Member
Any suggestions on adding a tool box to my CK 20?
/ CK20 tool box #3
I bought an orange Home Depot toolbox for my CK30H and mounted it behind the seat. It cost like $10 :thumbsup:
/ CK20 tool box #4
Might be a little late but here is how I set up a small tool caddy. 4"abs pipe with screw cap on top and end cap on bottom. You can cut to desired length as required. Plan to add a 6" carrier to other side for slings, shackles etc.
/ CK20 tool box #5
I did a nice little toolbox cage holder for my old Kubota that can be adapted to the CK20 for behind the seat.
http://www.tractorbynet.com/forums/customization/104110-l2800-l3400-tool-box-4.html
Will post up some pics next week on what it looks like.
First and second was for Army box the third was for a toolbox that can be lifted out if needed, that is what I liked the most was to be able to lift toolbox out.
/ CK20 tool box #6
The lift out idea is a good one. On my CK30 I recently replaced the original toobox with a Plano Ammo Box. It seems sturdy enough, has depth for hammer and other larger tools, and a top compartment for small stuff. I attached to the original holes that held the old box, and then attached the SMF sign to the tool box. So far so good, and did not cost much. I bought mine at Academy Sports. Here is link
Academy - Plano® Ammo Can
/ CK20 tool box #7
Got started yesterday on toolbox cage, will post up some pics in the next couple of days as to what it will look like.
/ CK20 tool box #8
Here is first conceptual placement (in other words, only place I could fit the darn thing without something hitting);
/ CK20 tool box #9
Looks great, but would interfere with backhoe. That was my reason for the pipe option. DSC_0198.jpg
/ CK20 tool box #10
There's another thread on here somewhere that has pictures of my ct122 (same as ck20) toolbox on it. Basically I removed the lawyer tube above the fuel tank and mounted a board with a boaters storage box from wally world. It fits perfectly and is very convenient to access
/ CK20 tool box #12
/ CK20 tool box #13
Thanks Jonnyc. Found your previous post, looks good. Will consider this option if I can finda similar weather tight box.
/ CK20 tool box #14
Here's what I did... on the cheap with some scrap angle-aluminum, scrap wood, $15 toolbox, and some bolts. It works very well...
/ CK20 tool box #15
Wow, that is what I call toolbox space there TSO, you can carry just about anything with your setup.
/ CK20 tool box #16
Well came up with another place which I believe to be better, it is easier to place and not as restricting as behind the seat.
I wanted to be able to still have the SMV and top link bar holder, this allows me to, am going to build a cage still for easy lift out of the box, the ammo box is just a conceptual part. I want to get another style box (shorter), the larger toolbox is to long I feel, the large box will fit though.
Darn this tractor is restrictive on toolbox placement.
/ CK20 tool box #17
Here is long toolbox with cage holder mounted, getting use to the size :
/ CK20 tool box #20
GMtb42 said:
I agree. Looking for new smaller toolbox.
It's not how big your toolbox is, its how you use it... Or so I've heard...
