Rotary Cutter JD 217 mower parts
/ JD 217 mower parts #1
moot
Member
Georgia
Kubota L3010
I have a JD 217 5' mower (serial # 3) that I have restored - except for the tail wheel rubber... split and pretty torn up...
The solid rubber tire is mounted on a split rim (3 1/2" hub), 13 1/2" outside dia, 4 bolt (5" pattern).
The solid rubber tire measures 15 1/2" overall, 12 1/2" inside, 4" wide.
Any leads on where I could find a replacement? New or Used, as long as it is serviceable.
/ JD 217 mower parts #2
Look up the part numbers under the JD web site Agricultural - Parts - Parts Lookup. They could do a search with the part number.
There are also salvage yards that specialize in old tractor parts.
Try Pete's Tractor Salvage in Anamoose, ND
Petes Tractor Salvage - Largest Salvage yard in the State of ND
That solid rubber wheel should be something that a tractor supply, fleet farm or farm supply big box store could match up.
2019 CAT 305E2 CR Mini Excavator (A62613)
2019 CAT 305E2 CR...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
1979 AM General 6X6 Truck (A65563)
1979 AM General...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
2022 EZ-GO ELITE...
