Rotary Cutter JD 217 mower parts
   / JD 217 mower parts #1
moot
Georgia
Kubota L3010
I have a JD 217 5' mower (serial # 3) that I have restored - except for the tail wheel rubber... split and pretty torn up...
The solid rubber tire is mounted on a split rim (3 1/2" hub), 13 1/2" outside dia, 4 bolt (5" pattern).
The solid rubber tire measures 15 1/2" overall, 12 1/2" inside, 4" wide.
Any leads on where I could find a replacement? New or Used, as long as it is serviceable.
   / JD 217 mower parts #2
Look up the part numbers under the JD web site Agricultural - Parts - Parts Lookup. They could do a search with the part number.
There are also salvage yards that specialize in old tractor parts.
Try Pete's Tractor Salvage in Anamoose, ND
Petes Tractor Salvage - Largest Salvage yard in the State of ND
That solid rubber wheel should be something that a tractor supply, fleet farm or farm supply big box store could match up.
2011 GENIE Z-45/25J ELECTRIC BOOM LIFT (A60429)
2011 GENIE...
Topsoil Trommel (A57453)
Topsoil Trommel...
2008 CAT 305C (A53317)
2019 FREIGHTLINER CASCADIA DOUBLE BUNK SLEEPER (A59575)
2019 FREIGHTLINER...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
2015 Chevrolet Tahoe, 192,897 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2015 Chevrolet...
