Buying Advice G174 need voltage regulator
/ G174 need voltage regulator #1
50dan
Hamilton, Ohio
Bolens G174
I need a voltage regulator for my tractor can anyone help?
And can someone post pics of all wiring please.
Thanks!
/ G174 need voltage regulator #3
Regualtors can be found on ebay. Search for "Satoh regulator" or "Nippon regulator". I don't personally have experience with the OEM Nippon-Denso regulator replacements but they appear to be the mechanical-type that origianally came with tractors that use the "K" series of Mitsubishi engines. The solid-state version is about half the thickness of the mechnical so it's a little easier to handle/replace. I'd recommend the solid-state type over the mechanical but feel the mechanicals are still good and can actually be repaired easier than the solid-states in my opinion unless you have a lot of experience with electronics and can remove the coating that seals the electronic in place. Both are roughly the same price.
/ G174 need voltage regulator #5
If you want all the details on the wiring I'd recommend getting the service manual. It also shows the schematics for the alternator, regulator, and starter which are helpful. Then you'll also get all the other service info you might need in the future. Parts lists and service manuals are a MUST in my opinion if you want to keep these tractors going into the future. I'm a bit surprised the manuals aren't readily available for free d/l on the net, but they are worth the purchase price from dealers anyway if they can help keep things running correctly.
/ G174 need voltage regulator #6
The Bolens G174 is the same as an an Iseki TX2160/TX1500F - built in the same factory,same HP, gearbox, axles, diffs, pumps, linkage etc- the only major difference is some of the early series to maybe c.1981 Bolens use a K75 2cyl Mitsubishi engine whereas the later Iseki's use a KB3 3cyl Mitsubishi.
Attached is an extract from the parts book detailing the voltage regulator part number you seem to require, together with the wiring diagram.
Here's a list of parts suppliers in the USA which I have copied from other threads/sites -unfortunately as I'm in Australia (where I use only Iseki dealers as there are no Bolens supplies) I have no recent experience with suppliers in the USA:-
A) ISEKI suppliers in the USA-
Sutton Tractor
6709 North I-35
Edmond, Oklahoma 73034
(405) 340-0268
Grey Market Tractor Parts
1-800-700-4739
Email: "mailto:suttontractor2@hotmail.com"
Rainbow Distributors Inc. (only distributor of new Iseki Equip. in USA))
1612 Kahai Street
Honolulu, Hawaii 96819
Phone: (808) 841-6203
Fax: (808) 847-1623
Email: "mailto:raindist@aol.com"
Website: "http://rainbowdistributors.com/Tractors/tractors.html"
Homestead Tractor
22311 Bear Valley Road
Apple Valley, California 92308
Telephone: 760-240-1062
Fax: 760-240-1126
Email: "mailto:hstractor@earthlink.net"
Sheaffer's Town & Country Tractors Inc.
320 Palmyra Road
Dixon, Illinois 61021
Telephone: 815-284-3226
Fax: 815-284-5050
Email: "mailto:sheaftractor@coiinc.com"
Southern Global Tractor
230 North Magnolia drive
Wiggins, MS 39577
Toll-free: 866-742-5748
Telephone: 601-928-7491
Fax: 601-528-9312
Email: "mailto:acker@ebicom.net"
Sonny's Farm & Home Supply
1733 N 200 W
Portland, Indiana 47371
Phone (260) 726-2808
Website: "http://sonnys_bolens.tripod.com/index.htm"
Valley Power Products, Inc.
3646-5 Aerial Way Drive,
Roanoke, Va. 24018
I can supply new and used parts for the Mitsubishi engines used on some of the models. I also sell manuals for the Bolens versions, from 15 to 27 hp. Call 800-609-5110, "mailto:vppinc@rev.net" or
We sell parts and manuals for Satoh/Mitsubishi tractors. 540-345-9650
Monarch Products
Glow plugs and spark plugs, with cross references by manufacturer, engine number, and tractor model.
1-888-800-9629
"http://www.sparkplugs.com"
B) Bolens suppliers in the USA
Bobby Bruneau at the Bolens Boneyard in Charleston S.C.
All Bolens parts but really strong in Large Frames.
(843) 889-8377
Bob Fenn at Horizon Equipment in Dunstable MA
Fast shipping on Bolens parts orders.
Very knowledgeable and willing to help.
rfenn@bolensman.com
Don & Pete Duff in Thurmond NC
Super Eaton Hydro knowledge and good with Wisconsin engines too.
336-874-7730
mrdadsr@aol.com
Richard Show (aka Blackjackjake) in PA
Good all around source for Bolens parts and attachments, VERY fair pricing.
rlshow4@comcast.net
Ray's Mower Shop in PA.
Good inventory of Bolens parts. Very knowledgeable.
Call Gloria or Noah at 610-367-2078
RMS1050@aol.com
Richter Power Supply in CA
Wisconsin Engine Parts
800-248-6476
Sweigard Bros. in Halifax, Pa
Bolens NOS parts inventory
swebros@aol.com
717-896-3414
Outdoor Distributors
Click on 溺TD parts, then enter the Bolens part number.
Lawn Mower Parts SnowBlower Parts and more Outdoor Distributors - Lawn Mower Parts
Plano Power in Plano, TX
Good source for Wisconsin parts.
(972) 423-5220
parts@planopower.com
Milaca Lawn and Garden in Milaca, MN
Very Good source for Kohler Parts and Parts Lists
http://www.milacalawn.com/parts.asp
Click on the 撤arts Look-UP box
then click on the Catalogs box and click on the drop-down list.
Jim Perlik for Bolens/Iseki Diesel Parts
jmperlik@yahoo.com
Sam's Bolens
Sam's Bolens
Wisconsin Engines Parts & Supplies
1000's of parts in stock!
wisconsinengines@earthlink.net
(814)766-3675
Trust this assists - the Bolens/Iseki's are great little tractors & real easy to work on(IMO far better than Kubota's which I also own)
Thanks for the replies! I love this tractor and want to keep it running. Thanks for the help!
/ G174 need voltage regulator #9
Yes, it will work.
/ G174 need voltage regulator #11
When you say "get this thing running" you mean just fix the charging circuit? It should run w/o that.
No, I bought my tractor non running. I was told it needed a "starter" and a "battery". When I got those replaced I bought new cable because the existing cables were butchered and so was the voltage regulator. The VR looked as if someone spliced in some wires, one was cut from the plug, and two were soldered on the inside guts. I didn't look good at all. So now that I have all new stuff, I hope this thing fires right up. I was told it ran good last year...hopefully...the guy did seem trustworthy and had nice house, cars and stuff.
/ G174 need voltage regulator #13
As long as you have a starter and decent battery you can try to get it running that way. All you need is the battery going to the starter main positive pole and then you can jump the solenoid to the positive of the battery and get it to crank. Of course, the ground must be connected to the frame as well and you need to pull the jumper to the starter solenoid as soon as the engine starts. I just picked up a G172 that has a toasted electrical system and I can start it that way. It helps to jumper to the glow plugs for a few seconds before going to the starter solenoid as these engines are difficult to start w/o glow plugs.
If the wiring has been "butchered" I'd avoid it altogether until you evaluate the rest of the tractor in it's entirety and see exactly all that is wrong if you can. It may take a major investment to fix everything back to original operating conditions, especially if there are gear problems along the way. Hopefully that won't be an issue and likely it will not. I can tell you that from owning five of these tractors second-hand, none of them came with fewer than roughly a half-dozen problems ranging from broken gears to poorly rebuilt engines in the worst cases and the gambit of other less-significant problems such as nobody doing basic maintenance during the last couple of decades.
If everything else does check out, consdier yourself very lucky and at least change all of the oils and filters and grease all the fittings that need it.
/ G174 need voltage regulator #14
Ironically my voltage regulator on my G154 just went too. It actually may have been bad for some time, but my 1 year old battery had overcharged, and was dry, and the plates were bent. I had to replace the battery, and I found that it was charging at about 18 volts. The voltage regulator is original and 30 years old, and I found that there were two wires that had fallen apart at the inlet to the regulator, so I ordered one last night. I checked all of the grounds, and my alternator is about a year old as well. I was surprised that it was close to $50, when you can find some for cars at around $8. I hope that it fixes my overcharging issue, and that yours helps with your tractor too! I am ok with slowly replacing old, worn out parts to make it last for another 30 years. I love my Iseki, and I used it yesterday for about 8 hours splitting wood with my 3 point splitter, and draging logs, and I worked it again today for about the same amount of time. It is an absolute work horse!
US ELECTRICAL TOOL CO.-500B BALL BEARING GRINDER (A64280)
US ELECTRICAL TOOL...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2014 JEEP GRAND CHEROKEE (A64280)
2014 JEEP GRAND...
MASSEY FERGUSON 4243 TRACTOR (A64280)
MASSEY FERGUSON...
UNUSED AGT ATK-B1000 TWO-POST CAR LIFT (A64281)
UNUSED AGT...
UNUSED ATSPOWER STAND-ON SKID STEER (A64280)
UNUSED ATSPOWER...
