PTO generator
/ PTO generator #101
As long as we are talking generators,I'm considering a portable gas generator for use during outages.My main concern is how much current is needed to start my well pump.I have a 450' well with a 1 1/2HP Goulds pump.It runs fine with a 240V 15 amp circuit breaker.I really don't need to keep everything in the house running all the time,just a little furnace here,or the fridge a little,etc.I just don't want to hurt the well pump.Would be happy to turn everything off just to pump some water.I've been looking at 5500 run/6900 peak or 6500 run/8000 peak units.Would one of these be sufficient?Or simply how many peak watts needed to start my pump?
Yes,I'm asking this on a tractor forum.We rock here!Thank you in advance for your replies.
Deep well pumps draw many times their running current to get started depending on your conditions. Here is a good thread that discusses this:
http://www.tractorbynet.com/forums/...ons/256041-what-best-generator-our-needs.html
/ PTO generator #102
I finally got my Rural King 15kw PTO powered generator up and running today. Voltage and hertz very stable while testing. Tractor seemed at ease powering it at 540 rpm. Now I need to get my 50 Amp etnrance box installed and hooked into my main panel using a interlock.
We got caught off guard during the last major power outage so when I heard about Sandy we drove 50 miles to a Rural King and purchased a 15KW PTO-generator too. This particular model uses AVR (automatic voltage regulation) which is supposed to make it safer around electronic equipment and gawd knows we have a lot of that around here.
Just last month the PC board went out on the Reznor overhead heater located in the pole barn. Probably caused by a voltage spike. I'm in the HVAC industry and that board still cost $300.
I will say that the PTO that came with the generator was to short for my application but the Rural King store made it right for me.
Our New Holland will sit in the pole barn and feed the power underground to the house to keep things online.
Here's the specs on the generator
/ PTO generator #103
The PTO shaft was worthless that came with the generator and Rural King doesn't respond to any of my emails to them even though a piece was damaged on the generator. Luckily I could fix it myself but I would recommend anyone to shop somewhere else if possible. Even Harbor Freight has a better customer service than Rural King in my opinion.
/ PTO generator #104
Here's running a 1-1/2 HP motor, that's = 1119 watts, his breaker is 240 * 15 = 3600 but the breaker isn't blowing when the motor starts in fact the breaker is most likely rated 30 to50% over his load. At 2400 watts (240V * 10A) he's a little over 2 times his rated HP. Motors draw is limited by wire ratings and sizes, you can't continually draw more than the wire current rating. At my conservative 3 times over rated HP he's more than safe in his energy calculations.
I think a motor starting load is a product of load regardless whether the load is a well head or a fridge compressor. Using more than three times is overkill, regardless of the application.
Are you saying well pumps draw more current than any motor with the same load? How much more than 3 times do you think he needs?
/ PTO generator #105
Rural King won't even respond to me about the defective part that came with their $1200 generator even though it supposedly has a warranty. This has got to be the most dishonest retailer on the planet. It is unbelievable how they handle themselves.
/ PTO generator #106
I had Rural King call the vendor while I was in the store. They admitted to Rural King that they knew there was a problem with the PTO shaft and that they were working with the supplier to resolve the problem.
What part was damaged on your generator?
/ PTO generator #107
Forget the email. Call them. Just a thought.
/ PTO generator #108
You bring up an excellent point that I think most people overlook. I don't need a generator for a one day outage. I need it for extended outages. My solution was to buy a large generator that I can run for short durations as needed and a Honda EU2000 that I run for the fridge and a light or two. I can run the EU all day on about 1 1/2 gal. of gas. I can go a long time without a huge quantity of fuel on hand.
Remember - Harbor Freight Black Friday Special $88.88 Harbor Freight Black Friday / Cyber Monday Ad Scans, Deals, Previews and Secrets at Slickdeals.net
And that is an important, but often overlooked point. You need to secure your fuel supply for expected duration, plus a safety factor. If you burn a gallon of gas an hour and run 24/7 and it takes 3 days for power to be restored that's 72 gallons, or 15 of the 5 gallon gas cans.
In another generator thread I mention tri-fuel conversion kits which let you burn gasoline, natural gas, or LPG on your existing gas generator. Winco (and others) also make tri-fuel generators. Their 8KW burns about 1.5 gallons/hr on LPG (Winco HPS9000VE Portable Generator - HPS9000VE - 8,000 Watt TriFuel Generator w/ Electric Start B&S Vanguard Engine). I've got two each 250 gallon LPG tanks I try to keep filled, that would be good for about 300 hours.
Where I'm retiring I'm setting up IBC totes for diesel and water.
That's about 300 gallons each.
Right now on the news they are showing the multi hour lines for gas, at gas stations in New Jersey. There's nothing stupider than waiting till the last minute to get gas (unless you don't plan on living that long).
/ PTO generator #109
Neil, Is Tiger no longer going to make pto generators or just no more 20k?
/ PTO generator #110
Motor inrush current can be more than 6 times running current depending on the NEMA Locked Rotor Amp code usually listed on the nameplate of the motor. Here is a chart for reference and how to use it. NEMA CHART
/ PTO generator #111
It was just the cover plate for the overflow plug on the gear housing. The factory plug was tapped so crooked it wouldn't seal and the threads that were cut were absolutely horrible. I welded a 1/2" plumbing fitting over it so now it works. Not a big deal but a person shouldn't have to modify parts from a new purchase. Furthermore, Rural King should have responded to my request(s) instead of just blowing me off and stating the issue is "closed" in their email replys even though they did nothing nor contacted me. What did they do for you regarding the stubby pto shaft?
/ PTO generator #112
Gentlemen-thank you very much for the helpful replies!Thankfully I'm not in need of emergency power like our eastern friends.I must admit I made an error in my original post.My well pump is on a 20 amp breaker.not a 15 amp as previously stated.Hopefully this will not effect your calculations too much.I'm reviewing Dark's thread and Rob-d , CrazyAl and Dex info as well.Please accept my apopogies.Thank you again!
/ PTO generator #113
I also have a 20 amp breaker for my pump. You can do the math to figure out the minimum size generator needed but I would factor in some extra. For the extra few bucks a 5000w or 6500w generator will cost you over a 3600 or 4200 it's not worth the savings.
/ PTO generator #115
they are getting out of the PTO generator business. I bought out about the last 40-50 PTO generators they built, but they are done manufacturing. The company (Dynatech) is still in business and doing fine, they will continue to stand behind any warranty claims. They just where not finding the business profitable any longer.
/ PTO generator #116
That's locked rotor amps! What happens when you lock a rotor on a motor? You blow the breaker! It's not the same as starting amps.
Motor Calculations | NEC content from Electrical Construction and Maintenance (EC and M) Magazine
" Motor locked-rotor current. If the rotating part of the motor winding becomes jammed so it can稚 rotate, no counter-electromotive force will be produced in the motor winding. This results in a decrease in conductor impedance to the point that it痴 effectively a short circuit. What痴 the result? The motor operates at locked-rotor current, often six times the full-load ampere rating, depending on the motor Code Letter rating [430.7(B)]. This will cause the motor winding to overheat and be destroyed if the current isn稚 quickly reduced or removed."
Electrical Motor Calculator
Plugging in 1 hp , 90% efficiency, 85 PF (power factor) and 230V to the calculator in this link.
You get:
1 phase = 4a.
FLA = 5A
What does FLA stand for? Full Load Amps! At full load the motor draws 5A, 230V * 5A = 1150W; 1 HP = 746W FLA for a 1 HP motor = 1150/746 or 1.54 times.
Now look at the chart for starting amps, what does the FLC state? 150% to 300% of running current and what's 300%? It's 3 times, exactly what I said. I work with this stuff everyday my systems are built on these calculations. Are you off the grid running several inverters on a daily basis?
/ PTO generator #117
Here's another link:
Generator Sizing for a Motor Load - Electric motors, generators & controls engineering FAQ - Eng-Tips
Rules of Thumb:
Most generators are capable of delivering 300% of the rated current for 10 seconds, which is sufficient time for most induction motors to get up to the rated speed. So for DOL starting a generator rated 2 to 3 times the kVA of the motor will easily supply the starting kVA of the motor and for a star/delta start even a generator sized just above the rated motor kVA will be sufficient. These rules of thumb generally result in generator size that will keep the voltage dip during the motor starting within acceptable limit.
/ PTO generator #118
We do the same thing with the EU2000. Last year when we where out for a week up here I loaned it to my neighbor to do exactly that. It's expensive for its size but you can keep your fridge going and then move it to other appliances if you need to. The big plus is how little fuel it uses, the low noise is very nice too. The EU2000 has an energy saving feature that works well also.
If you can afford two gens, go with this one and a larger one if you can, that's my advice.
/ PTO generator #119
brandoro said:
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=287010"/>
Someone asked about running the tractor inside with the door closed. This is a photo of my setup, since modified slightly for my current tractor. The exhaust is regular exhaust pipe from a muffler shop.
Please, if you haven't, get a carbon monoxide alarm if you are going to do this.
/ PTO generator #120
They gave me another PTO shaft, one that was longer.
Called customer service and after some checking she said the supplier shipped out some with an inappropriate pto shaft. They are going to send me a new one. When I talk with a live person at Farm King they couldn't be nicer...their IT must be a real joy given my email responses.
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63118)
2019 Cadillac XTS...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
Hyundai Robex 55W-9A (A64047)
Hyundai Robex...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2019 KENWORTH T880 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T880...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63118)
2020 Takeuchi...
