JD X500 mower deck
/ JD X500 mower deck #1
parsonbw
Member
NC
JD X500
What is the easiest day to remove the mowing deck on the above tractor.
The owner's manual is not too much for these 66 year old eyes.:confused:
/ JD X500 mower deck #2
I can remove my deck on any day. (None any easier that another.) But weekends are usually the best days for me.:laughing:
If you mean which WAY, then I cannot explain it any better than the manual does.
/ JD X500 mower deck #3
What are you asking about? Do you not know how to release the belt or the deck from the mower or are you trying to find out the easiest way to get the deck from under the tractor?
/ JD X500 mower deck #4
There are several steps involved to remove/install the deck and you should follow the owner's manual to do it properly. If your reason for removing the deck is cleaning and/or sharping the blades I would suggest investing in a Mojack Pro to save your 66 year old back.
Mower Lifts | 750lb Lawn Mower Lifts| MoJack PRO| MoJack
I'm sorry fellows. I meant to say which way, but thought there was a trick of the trade to remove the deck the easiest. My manual is not the best, at least, to me. A little advice and better explanation than the manual would be helpful. It's always helpful to hear from experience, what to pay attention to, etc.
/ JD X500 mower deck #6
i too would suggest the mojack..use it on my x500...they are now on sale at tsc
Thanks much, men. Mojack it is.
/ JD X500 mower deck #9
I would suppose for the X500 I would need the mojack xt because of the weight, right?
The X500 weighs 800+ lbs. I don't know how much that would be for the front end only. Assuming it's 400 lbs, the XT's 500 lbs capacity should be adequate. However, I would recommend getting the Pro model anyway because it has a 750 lbs capacity and a better crank mechanism. I personally would feel more comfortable getting under a 800 lbs mower with a heavy duty lift holding it up.
rekees4300, you're right. Don't want to take any chances, too old to mend like I used to.
Thanks for all the responses.
/ JD X500 mower deck #11
Parsonbw.
Do you have a smooth surface to park your X500 to remove the deck? If so, First: Raise the deck to the top. Second: release the pins and move all the gauge wheels to the sideways position. Third: set the cut gauge knob to the lowest position. ( the unmarked space on the scale) Fourth: lower the deck to the bottom, and it should be sitting on the wheels. Fifth: release the belt tension lever, and take the belt off the front pulley. Sixth: Pull the two "J" hooks out at the rear lift levers to disengage them. Now raise the deck lever. (The deck should be still on the ground) Seventh: release the park brake on the tractor so you can roll it slightly to disengage the front lift rods. Once they are unhooked, roll the deck out from under the tractor.
Removing the deck is really easy, and is not strenuous if you are careful. Putting it back on is also just as easy. I remove my deck to clean it, and inspect it at the end of each mowing season. The only part that can be difficult is turning the deck over once it is removed. Even still, with a helper that should be easy too.
Parsonbw.
Thanks so much, Eric. Exactly what I was looking for. Grateful
/ JD X500 mower deck #13
Makes life really easy!
/ JD X500 mower deck #15
Ok the pro lift is great but I am also 66 years old and I find removing the deck on my 54" deck on my x720 easy. I can do it in 3 minutes or less with no lifting. The hardest thing on removing my deck is disconnecting the drive shaft which the x500 deck doesn't have. First you raise the deck up and rotate the gauge wheels 90 degrees. There should be a slot for the pin to fit in to. Lower the deck on to a smooth surface. On my deck, there is a lever on the front of the tractor that you unlatch and it drops the front of the deck, push the deck back and remove the drive belt. Roll the deck out from under the mower. I have also purchase a inexpensive rope hoist from Amazon to lift my deck so I can get to the under side. I have also built a dolly that allows me to store and move my deck in the upright position. 4, 10 inch wheels from harbor freight, a 5/8" threaded rod and a few nuts and you have a dolly. I believe that even with a pro lift, at some time you will need to remove your deck. Hope this helps.
/ JD X500 mower deck #16
Oh, I agree, removing the deck is not bad on these Deere's. But I sharpen my blades (3 as you know) at least every 3 weeks. Not to mention cleaning the mulch away. I don't want to remove the deck every time. I will take the deck off a couple times a year to do cleaning and greasing.
1995 John Deere 5200 45HP 4x4 Utility Tractor (A61572)
1995 John Deere...
iDrive TDS-2010H...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2012 Peterbilt Semi (A64047)
2012 Peterbilt...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
Kubota Z232 (A60462)
