Compact Spare Tires
   / Compact Spare Tires #11
Check a late modelChrysler/Dodge mini van. Those should be your 5 on 120mm bolt pattern, plus should be fairly inexpensive at the salvage yard.
Ken
Ken
Thanks. I will check the lug pattern.
Chris
Ken
I called my tire guy then the local Dodge dealer. They both confirmed that late model mini vans (08 to current) are 5x127mm and prior to 08 they were 5x114.3mm. Again my BMW is 5x120mm. Thanks for the lead but its a dead end.
Chris
   / Compact Spare Tires #14
Chris
Minivan is FWD, Your BMW is rear drive, eh? Offset is very different. Wheel won't turn after you tighten it up and the brake caliper will be trashed, maybe the wheelhouse, too.
Get a can of fix-a flat. Your Falkens are plastic. Wet traction will be pretty bad. If you have a wreck and hurt someone and their lawyer finds out, issue a Quit-Claim deed for your house to a friend. Its called 'forseeable misuse'.
I've used the compact spares on my hay elevator, but they go soft after a couple of years... Make great signpost bases, though.
   / Compact Spare Tires #15
As far back as 21 years ago, in a tire dealership, we'd get requests for compact spare tires; sometimes including a wheel and sometimes not, and the only place we could get them was from the car dealers. I wondered whether that had changed or not, and apparently not. I consider myself lucky that both of our old Fords have full size spares.
i know they are difficult to get used as well.
I have a farmall C, and the fronts are not regualr tri ribs, but compact car maypops.. probably 12 er.. 13"
i had one let go last year and had a heckuva time getting a used maypop for it...
   / Compact Spare Tires #16
i'll ask the dumb question.
what's a falken.. and what part is plastic? the rim?
I'm not familiar with them
   / Compact Spare Tires #17
Falkens are a high performance specialty tire popular with 'drifters'. Drifting is a racing/driving style that utilizes very high sideslip angles when maneuvering on a flat track. Sort of like dirt track racing. Drifters don't have as much power available, though.
The plastic refers to tread compounds used to get very high grip as the tread melts/ablates. Great for burnouts, too. (the kind that make a LOT of smoke. Well I suppose that could be the description of the driver, too, now that I see it in print).
If you want the best (summer) tires for that car get the O.E. Continentals (non-runflats). Real BMW O.E. tires have a special symbol on them that your dealer may not even know about. Best winter tire is a Bridgestone Blizzak IMHO. Ride is awsome, wet road is fantastic, snow grip is pretty darn good. Wear is not so great. I get mine at COSTCO (coupon sale). Wear them on all my vehicles, now.
Good point about the RWD vs FWD. I will just continue to search for a BMW spare. I have 2 trips to fly this week. Tomorrow I am going to Raleigh and Friday to DC. I will call some junk yards.
As for the Plastic and wet traction comment I have no idea what you are talking about. We are getting rain and freezing sleet here all day in North Eastern Indiana brought to us via the Hurricane. I drove the car about 80 miles today. Its way better in the wet then the Bridgestones were.
I will never use Fix A Flat. I would pay the $75 tow fee before I did that or just go get the tire with one of my trucks and run it to a tire store. Kicker is I am getting ready in two weeks to drive this BMW to Charleston and would feel much better even with brand new tire having a spare on board.
You could not give me a set of Continentals. I had a set on my New F-350 and they were horrible. Wore out in under 25,000 miles and would get you stuck in 4 low on wet grass. They loaded up and turned to slicks. As I said before this is now my 3rd set of Falkens and I put these 722's right up there with the best of the best tires on the market. The Blizzak's are good but not really need having 2 4x4 trucks at my disposal.
The 722's are a all season radial with great specs. Here is a link. http://www.falkentire.com/tires/car-tires/azenis-pt722-a-s
I am familiar along with my tire guy about the BMW symbol on tires but that does not mean that is what is the best for a particular application.
Chris
   / Compact Spare Tires #19
Honda Ridgeline trucks have 17" or 18" wheels with a 5-hole pattern that may fit your car. This may help you because the truck comes with a compact spare, but some owners buy a full-size spare for towing and then sell the compact. One such offer is on the St Louis Craigslist:
Honda Ridgeline Spare Tire
He wants $20. It may be worth it to drive West, out of the way of Sandy's remnants.
EDIT: It seems BMW and Ridgeline wheels do indeed have the same bolt pattern, 5x120, and should be interchangeable:
Looks like Honda stole BMW's exclusive 5x120 bolt pattern... - Bimmerfest - BMW Forums
   / Compact Spare Tires #20
heck.. if this was a tractor.. just find one close and drill it out and use washers.. :) ;)
2005-  3412 ENGINE (A50854)
2005- 3412 ENGINE...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2017 Rogator RG1300B Dry Fertilizer Applicator (A51039)
2017 Rogator...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2013 Doyle Dry...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
