woodlandfarms
Super Member
- Joined
- Jul 31, 2006
- Messages
- 6,155
- Location
- Los Angeles / SW Washington
- Tractor
- PowerTrac 1850, Kubota RTV x900
Pictures please! Congrats on the new machine.
Well, its been a full season of use, 45 hours, for the GR2120. It's our first year at a property that needed, and still needs, some work and attention. The 54" mower deck has been great and reduced mowing time significantly. What once was a 1.5 hr+ job of hanging and sliding has turned into speedy 1 hr cut. The speed of the machine, coupled with the climbing and steering control has made mowing quite enjoyable. I hit the small hillside about twice a month during the summer and the grip of the machine has significantly reduced tire damage to the turf. The mulching kit has been great. Grass clipping have rarely ever clumped in the yard. Also, it recently did a fine job when I simply put the deck around 3-3.5" to mulch the leaves. I have been very satisfied with the mower, and setting it at 2.75"-3" has been a lot more healthy for the grass. Thats a bad looking mower.:thumbsup:
Is the engine bogging down and running out of power when you go up the hill or is the hydro struggling to pull the hill?
whiskeyc said:Engine rpm's sound like they take a small hit, but the wheels just stop moving. I keep the motor at "full rabbit".
I can run up the hill, park the tractor near the top, let out the brake, hit the go pedal, and the machine might creep forward a bit, but ultimately it will stop. I can make the hill every once in a while if I don't have to slow and take a specific angle near the top. That path requires some unwanted lean.
I would say the hydrostatic transmission is the issue. What wear parts should I be concerned with? The tractor has always done this. Maybe I should change fluid type. Any suggestions?
Thanks locknut. I'll try to do all of the climbing at the beginning of my mow.
I sent my tractor to the dealer to see if they had any input. They were going to do the 50hr service and sharpen my blades for the season anyway. They said they let it run for a while, then ran it up and down their test hill, which is about 25 degrees, a little longer run than my hill, and the tractor didn't have an issue. They said it didn't stop crawling. Of course this was after the service on a cold day, and they mentioned that if there is some blockage in the filter that it could possibly cause problems like the one I was experiencing. Have you ever heard of a filter causing such a problem?
