Canopy/Lights on a budget ($60)
/ Canopy/Lights on a budget ($60) #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I just finished putting a canopy and lights onto my L4200.
It all started with a friend giving me an old canopy and bracket (from a Massey SCUT, I think), which was cracked due to a tree falling on it or some such disaster. I had the thing kicking around for a couple of years, then finally got to putting it together. I had to do a little cutting/grinding to re-set the support bar to be at the right angle for my tractor, then welded it in position and bolted the assy. onto my ROPS. I fixed the cracks in the canopy with zip-tie stitching and epoxy, then spray painted the canopy orange on top, black on the bottom. Total cost for canopy: $10 (spray paint)
On to the lights. I bought 2 sets of 55W 4x6 white halogen fog lights at Autozone for $25 a pair. I put a pair of lights facing forward and a pair facing backwards. I mounted the lights to the top of the canopy, using the canopy mounting bolts. That way, if I want to take the canopy off, or it breaks again, I can leave the metal structure to use as a light bar, and nothing will change with the lighting setup. The lights came with switches and a rudimentary wiring harness. I used the switches, but tapped into my tractors main fuse block and did all of the wiring using 12ga outdoor lighting wire, which is perfect for this application for obvious reasons. I had the wire left over from when I built a home-theater room - it makes outstanding speaker wire. I pulled the included switches out of their mounting plates, then inset them directly into my dash for a factory look. Front and back pairs are switched separately, and all 4 lights are run on a common 30A fused circuit, fused at the main block.
These are the switches - two rocker switches to the lower left of the steering wheel on the vertical section of the dash. The big black button on the right side (next to the key) is my glow-plug bypass button, which I also installed while doing this project. My glow plug controller died, so now I just push the big black button when the key is on to engage the glow plugs - indicator light turns on while button is depressed too.
These show the lights and canopy. Not bad for $60, if I do say so myself.
JayC
/ Canopy/Lights on a budget ($60) #4
Looks great. I like it. I will start looking now for a used canopy so I can do same.
Nice job; now you can go Bajaing.
Not exactly. These lights are a game-changer for me. I keep my tractor at my camp, from which I ski every weekend during the winter. I have 1000 ft. of driveway and about 5000 sq. ft of parking areas, and clear them with a 6' blower on the back of my tractor. During weeks where there was significant snowfall, I couldn't go up on Friday night since I couldn't run my unlighted tractor at night. I had to wait until Saturday morning, and by the time I got there and got everything cleared up, then made it to the mountain, it was 3-4pm, and I hate night-skiing. End result two years ago, when we got 2 feet of snow almost every week, was a loss of half of my ski days during the best conditions in 20 years. It didn't matter last season, since it only snowed twice all winter so I was up every Friday even without the lights. However, the acorns this fall read snow, so with my new canopy/lights AND glow plugs (for those 5 degree nighttime starts), I'm all set for Friday night snowblowing and skiing during the day on Saturday. Very excited.
JayC
/ Canopy/Lights on a budget ($60) #6
Nice job.Judging by the shape of the canopy,I would say it is the same one that Kubota sells.I bought one for my 3240 and it was quite expensive for what it is.
2013 John Deere 210G Excavator (A60352)
2013 John Deere...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
International 9200 (A61307)
International 9200...
DEUTZ MARATHON...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
2014 18ft. Parker Performance T/A Trash Trailer (A60352)
2014 18ft. Parker...
