Boom Pole - Simple - Long & high reach
/ Boom Pole - Simple - Long & high reach #1
crash325
Elite Member
Tucson AZ
New Holland TC-45
First off let me state this boom is NOT for HEAVY lifting.
The whole object is long reach or high lift. Construction is pretty simple and quick. By adjusting the bucket to pole chain it can pivot left or right. It is held to the bucket by a 3/4" bolt, left slightly loose.
As shown by the ball I have a hole in the bucket bottom. If just scooping loose soil or sand, often the ball is just left in place. Real handy for moving trailers around. It has also been used for lifting and dumping my 18 footer, when loaded with sand or gravel.
boom pole 1.jpgboom pole 2.jpgboom pole 3.jpgboom pole 4.jpgboom pole 5.jpgbucket ball 1.jpgbucket ball 2.jpg
/ Boom Pole - Simple - Long & high reach #2
Looks useful, but I would prefer a rigid top brace instead of a chain. If you had a load on it and did a high lift but went a little back past vertical, the only thing keeping it from falling on you is the inch or two of the pipe behind the bolt.
Bruce
Bruce
Depending on how the chain is adjusted that is possible. Picture 5 is full back and it still has forward slant. The operator also should watch his load or not pretend to be an operator. Just me & my way of thinking.
Bruce you are most always on top of things. Nice :cool2:
/ Boom Pole - Simple - Long & high reach #4
I try to look at things with Fail-safe in mind.
Bruce
Bruce
When working with a front end loader there is no fail safe. As a fully loaded bucket goes up it also needs to roll forward or near the top rocks, dirt or what ever is going to fall onto the tractor or operator.
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
2025 Tophat Dump Trailer (A64047)
2025 Tophat Dump...
JOHN DEERE 50P EXCAVATOR (A62129)
JOHN DEERE 50P...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A63118)
1995 Ford F-250...
