3-Point Hitch If you had to choose 1: Hyd Top Link or Tilt Link?
/ If you had to choose 1: Hyd Top Link or Tilt Link? #1
JD 4520
Snohomish County WA
John Deere 4520
I would like to have both a hydraulic top link and tilt link BUT I only have a single rear 3rd function SCV, so I am thinking which would be most useful to have as hydraulic and which one to leave manual?
The manual top link is relatively easy to adjust while the tilt link is not. It seems like a tilt link would be the most useful to have as hydraulic. What are your suggestions and what am I not taking into consideration?
/ If you had to choose 1: Hyd Top Link or Tilt Link? #2
From your list of attachments/implements it appears the boxblade is the most likely candidate for using the hydraulic adjustments on a frequent basis. For that reason I would go for the top link being hydraulic. This would be used much more than the tilt cylinder for most boxblade work. On my 4520 with three rear outlets I use the top link cylinder the most, the tilt cylinder second and the hydraulic scarifiers the least.
/ If you had to choose 1: Hyd Top Link or Tilt Link? #3
I vote a toplink. I think most people are inconvienced by getting off and on the tractor to adjust the top link more than the tilt. Then again, it all depends on what each individual is doing mostly. May i ask why you cant just ad another set of remotes?
/ If you had to choose 1: Hyd Top Link or Tilt Link? #4
Adding another set of remotes is not a simple inexpensive task I would assume-your thoughts?
/ If you had to choose 1: Hyd Top Link or Tilt Link? #5
Top link for sure. I am frequently adjusting my top link and most of my tilt adjustments are straightening things back up because I pulled or pushed the wrong remote lever. Still I am glad I have both but if I had only one it would be the top.
You are correct and probably not worth the couple of thousand with the extra link and another set of remotes.
/ If you had to choose 1: Hyd Top Link or Tilt Link? #7
I have three sets with TnT, but if I could only have one, it would be top link.
/ If you had to choose 1: Hyd Top Link or Tilt Link? #8
I don't have either, but if I had to pick one, it would be top link. I seldom adjust my side link while working with my box blade, but I am adjusting the top link all the time. Also, having an adjustable top link would allow easy tilting of a hay spear, pallet forks, or carry-all, which would be a big advantage.
/ If you had to choose 1: Hyd Top Link or Tilt Link? #10
Have both and the top link cylinder is the one used most. Installed 2 additional remotes myself and the hardest part in my opinion was removing a rear tire. If you want another remote, get one cause they aren't hard to install. If you do get in a jam there's a lot of folks here willing to help.
/ If you had to choose 1: Hyd Top Link or Tilt Link? #11
I dont have either, but have to agree with others that the TL would be best in YOUR case with YOUR current implements.
If I ever get a hydraulic link, for me it would be the side link. Cause I dont have a BB, and use a rear blade ALOT. AND I can reach the TL from the seat, but not the sidelink.
/ If you had to choose 1: Hyd Top Link or Tilt Link? #12
Adding remotes is expensive especially if you have the dealer do it. If you have a reasonable amount of mechanical ability and the time and incliation to learn a few new things you can add a couple sets of remotes yourself for $250 to $300 range. It is really not hard. There are several projects on here you can look at if interested.
I vote for the TL also because of your BB. Like LD1 says when using my rear blade the side link is usually the most useful one. For the landplane I use both the top link and side link. Both are very handy.
/ If you had to choose 1: Hyd Top Link or Tilt Link? #14
I just fiigured he might want to try and tackle the job himself if he wanted. Didn't know if thought he was limited indeffinately
/ If you had to choose 1: Hyd Top Link or Tilt Link? #15
Installing a manual diverter valve would be pretty easy and cost about $500 including hoses. Then you just select which cylinder you want to move and still have only one lever.
/ If you had to choose 1: Hyd Top Link or Tilt Link? #16
Another vote for "top link" here.
I have both and use the top link at least 10X more than the tilt. Hooking up implements, regulating the bite of a blade or rake, leveling a 3PH disc (or tilting it up for transport), and leveling any other implement are uses that immediately come to mind.
The screw tilt arm is not that difficult to use although when plowing the hydraulic tilt is a real plus for adjusting after the first pass. Others like the tilt for grading with a blade.
If you can somehow swing the cost of another remote then it will open up a lot of options besides just T&T. You can use the "tilt" remote to run hydraulics on an implement like hydraulic rippers. You will temporary lose the tilt function of course. Then you will spend on the second remote as well as a bunch of new hydraulic implements. It is amazing how the money just disappears! :D
/ If you had to choose 1: Hyd Top Link or Tilt Link? #17
I would highly recommend the JD electric diverter valve kit and top and tilt kit for your rear attachments if the funds are available, that would leave your 3rd function remote open for your front attachments so you can use both at the same time. I've been doing a lot of fine grading this fall with my 3320 and have found that both the top and tilt are equally important whenever the tractor tilts, dips or rises on terrain changes. I love being able to adjust the box blade with the loader joy stick, after a while you don't even have to think about it, just like operating the loader.
Great and helpful comments by all. I am interested in the diverter kit. I plan to start with the hydraulic top link and progress from there.
You all are so helpful.
/ If you had to choose 1: Hyd Top Link or Tilt Link? #19
I vote for the toplink but once you get it you will want the sidelink too.
/ If you had to choose 1: Hyd Top Link or Tilt Link? #20
Id say tilt. Just from personal experience trying to crown roads with my box blade.
New/Unused Agrotk YC-32G Sawmill (A61166)
New/Unused Agrotk...
2013 GMC Sierra Service Truck, VIN # 1GD422C84DF134632 (A61165)
2013 GMC Sierra...
Welcome to the Farm Metal Decorative Sign (A61569)
Welcome to the...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2021 Forest River Puma PUT31QBBH 37ft. T/A Travel Trailer (A60352)
2021 Forest River...
