Identify Motor on Ford 9N
/ Identify Motor on Ford 9N #1
macecase
Princeton, KS
1965 John Deere 3020 Diesel and 1975 John Deere 4630 Diesel
Can anybody help me with more info on this motor? It is on a 9N that I just bought....
The serial number is not in sequence like others (ie 9Nxxx or 8Nxxx).....
Mine has AER 2778 stamped in the block. The engine looks just like what is on my 8N so I know it isn't a converted motor or anything.
I'm just dying of curiosity to know more about this motor. I'm sure it isn't original and doesn't look like an industrial engine (from the serial number).
Any thoughts, ideas or information is appreciated.
/ Identify Motor on Ford 9N #2
Perhaps a picture of the actual motor might help ...
Here are some photos. I hope these help.
One of them is the casting code on the header. It starts 2N..... which might give us clues as to the age of the motor.
/ Identify Motor on Ford 9N #5
It sure looks like the engine on my 2n unless someone replaced the block with an industrial block at some point.
Just a guess....Possibly this is an AER rebuilt engine? They have been in business for 60 years.
AER - Manufacturing
Judging by the serial number prefix, I'd say your guess holds water. I am going to contact them and see if they can tell me production dates from the engine rebuild. I'm just curious about it.
I am also trying to date the tractor itself... This image is what is on one of the rear axels. Looks like 4013 B followed by a pentagon. You cannot see the 9N which is in the shadow of this image. So, "9N 4013 B ⬠"
/ Identify Motor on Ford 9N #10
I'm not sure, I found a lot of info on mine from yesterdays tractors they deal in the old stuff.
Hope you have good luck
Randy
/ Identify Motor on Ford 9N #11
here's what I see.
it's still a studs n nuts machine.. thus early build... DOES have a tapped and plugged port/boss for a temp sensor.. and DOES have a blanked off plate, not just a boss, for a fuel pump.
these engines were used in early jeeps.. air comps.. milkers.. water pumps.. gensets.. etc. lotsa industrial applications... the fuel pump blank nd temp gauge plugged port bends me in that direction...
4013 is a left axle housing number.. and 4012 right.. is that 4013# you say on the left by any chance?
Hyundai GP Bucket (A68134)
Hyundai GP Bucket...
2015 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
2025 24in Bucket Mini Excavator Attachment (A66734)
2025 24in Bucket...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Autocar...
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
(3) HOLE STAINLESS STEEL SINK W/ SIDE TABLE (A65054)
(3) HOLE STAINLESS...
