wheel horse loader..
/ wheel horse loader.. #1
Bwgad96
Huntingtown,MD
Wayy to many.
I am being asked by a friend to start this thread so here goes... today we loaded his old wheel horse on the trailer. when we go to our destination the tractor would only go about 2 feet forward and backward. It would stall out and make some nasty grinding noises. It ran great going on the trailer. Any ideas? it has the 18 hp onan engine...
/ wheel horse loader.. #2
Would the engine make a grinding noise or the transmission ?
/ wheel horse loader.. #3
Sounds like transmission to me. I am not familiar with any Wheel Horse with an 18 HP Onan. Maybe a replacement engine? What model WH is it?
I am thinking it could be a D series. These has issues with parking prawl snapping if you forget to take the parking brake off and also come bolts shearing on the diff. and usually cracking the trans case.
/ wheel horse loader.. #4
I had the same issue when I was trying to pull a small tree out. Lol. I ended up shearing the key way off in the hub! Did you check that. It might be grabbing a little but then letting loose. Better check it befor it hurts the slot for it in the axel
/ wheel horse loader.. #5
That's a good thought.
Also if it is a D series it could be the hydro pump to engine coupler is stripped, although that makes a sound that is usually not described as "grinding".
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Teakwood Wagon Wheel Bench (A65583)
Teakwood Wagon...
Aluminum Hog (A65583)
Wooden Plant Holder (A64557)
Wooden Plant...
New/Unused AGT Industrial SDA-140T Track Loader (A65583)
New/Unused AGT...
Metal Sunflower Spinner (A65583)
Metal Sunflower...
