71 Ford 3000 color
   / 71 Ford 3000 color #1
dford
Member
north IDAHO
TC 35D 2001, 16LA,
Does anybody have the white and blue paint codes for my 1971 Ford 3000 3cy gas tractor. If possiable PPG.
Thanks
   / 71 Ford 3000 color #2
I'm using PPG code 12809 blue on my 1966 4400 and I'm satisfied with the match. The label for this code even prints out as Ford Tractor Blue. Here's a pic:
The white is actually a very light gray. I believe the PPG code is 32571.
Get a small quantity of each mixed up and make sure you are happy before you commit.
Thanks
By the way does your alternator have a tach drive on it? If so what is alternator make and model.
   / 71 Ford 3000 color #4
I bought the alternator conversion kit off of ebay that cheaptractorparts sells. It comes with a delco 10si 3-wire alternator with a tach drive installed, brackets, and wires. It was around $250. TISCO used to sell this setup but if you check their catalog its discontinued. I think this guy is buying the tach drives from TISCO and making them up himself.
I'm unhappy with the way the tach cable has to be routed with this setup. It makes for a sharp bend in the cable when it goes over the fuel tank. In fact my cable is binding. I'm going to lube the cable and see if it gets any better. If that doesn't help I guess I'll try a new cable. The generator has a right angle drive makes for a much better routing on the cable.
If I had it to do over I would probably buy a delco 10si for about $50 and either see if I can make it work with the angle drive off the generator or buy the tach drive from TISCO for about $75.
   / 71 Ford 3000 color #5
A 10dn also can be fitted with the tach drive.. though it's an external reg model..
soundguy
   / 71 Ford 3000 color #6
Rick,
Which Omni product did you use? Looks good
   / 71 Ford 3000 color #7
I have found that the TSC paint is a good match to the original colors. You can just get a quart, all you are doing is the fenders and wheels right. By the way looks good so far!
   / 71 Ford 3000 color #8
Guesseral,
Do you by chance know the correct ppg paint code for Ford tractors 1967-1990? Was it the same blue?
   / 71 Ford 3000 color #9
No I don't know any paint code numbers. I think there was only on ford blue tractor color, could be wrong.
   / 71 Ford 3000 color #10
i think there was only color too from somewhere around 64-90 but not totally sure.
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
