Snow Deciding between UTV or Compact tractor
   / Deciding between UTV or Compact tractor
Your responses have been great and most helpful. I think that the work side of this equation will likely win out in favor of the tractor; thanks for making my decision so much easier.
Symbion
   / Deciding between UTV or Compact tractor #12
Welcome to the forum. I have to agree with the others and think you will get more bang for your buck with the tractor. Being a self confessed novice spend some time thinking through your tractor needs before deciding on maker, model or size. Lots of options in the tractor market these days.
MarkV
Appreciate that; good advice MarkV. After, reading through so many great comments, I have to believe that a compact tractor will end up providing the best option. Now, will take your advice and research the many types and options. Thanks.
Symbion
   / Deciding between UTV or Compact tractor #14
Tractor, because it can do so much more.
   / Deciding between UTV or Compact tractor #15
I have an ATV, UTV and tractors. I use my tractors the most with a front end loader. IF I only had a UTV I would want a diesel with a dump bed.
   / Deciding between UTV or Compact tractor #16
Just got a tractor a few weeks ago. Before the tractor I did everything (mowing, plowing snow, driveway grading, brush clearing) with a utv or atv. A front mount snowplow on a utv is pretty efficient at plowing a driveway as long as the snow is not extremely deep. If it gets too heavy the front end of the utv will get pushed off track, especially if the snow piles up into a bank. I also have done a lot of snow plowing in reverse with a rear mount 3 point blade (kolpin dirtworks) on a utv. The back end gets pushed around a lot if the snow is deep, and it has a real problem with bottoming out. Tire chains help a lot. I used the 3 point scraper blade and landscape rake on the back of my utv to maintain my steep gravel driveway for several years. It was pretty effective, but took a long time if a lot of cutting was required. The utv 3 point implements are very light weight. You just have to be patient and careful not to be too agressive. I found traction to be the biggest limitation with the utv. The wheels just spin and dig in when trying to scrape aggressively going uphill.
In summary you can do much of the same work with a utv as you can with a tractor, but it takes a lot longer. When I first got the tractor I did in 20 minutes driveway grading that would have taken me 3 hours with the utv. However, I would hate to be without the utv because we use it a lot just for running around the farm, hauling hay bales, and dumping the poo cart. If we had to start over again it would be a tough decision which to get first.
   / Deciding between UTV or Compact tractor #17
No question, the tractor is the only way to go it's just too versatile, especially dealing with deep snow. Buy the UTV next year.
   / Deciding between UTV or Compact tractor #18
Tractor and a used golf cart to get the mail.
   / Deciding between UTV or Compact tractor #19
+1
I have a 1/4 mile driveway and I never fire up the tractor to go get the mail or check the game camera. I use the atv for that as the tractor is painfully slow especially on a trail. I used to plow the driveway with the atv too and it could move quite a bit of snow pushing downhill, but the tractor is definitely better for that.
Get both or if the budget is limited, the tractor and a used small bore utility ATV, they are very cheap.
   / Deciding between UTV or Compact tractor #20
+2 Tractor. No doubt.
Then, go to HD or a dozen other places and scratch the UTV itch with an inexpensive, but American made Sportsworks type UTV. They start at around $4K but nice, simple, reliable machines. A reconditioned golf cart is also a good recommendation. One can never have enough little things to drive around and enjoy! :D
But do get the tractor. Even if you downsized a model on the tractor, it'd still be an amazing workhorse, leaving the extra cash for a run-about vehicle.
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A56857)
2015 Vermeer SC362...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
1996 Timpte 46ft Hopper (A56436)
1996 Timpte 46ft...
8065 (A55852)
8065 (A55852)
Enerpac Hushh-Pup Hydraulic Power Unit, Model Per-132, Product Code B14880, 1/3 HP, 120 Volts, 1 (A59076)
Enerpac Hushh-Pup...
2017 Ford F-550 4x4 Cab and Chassis Truck (A56858)
2017 Ford F-550...
