1973 Ford 5000 Will Not Run
/ 1973 Ford 5000 Will Not Run #1
Oldyellowtractor
North, MS
N/A
Hi,
I have been trying to repair my dad's 1973 Ford 5000 diesel. The tractor quit in the field while bush hogging, it apparently had trash in the fuel tank. We cleaned the tank, added clean fuel, and replaced the fuel filter. We bled the pump and the tractor cranked and ran for about 1 hour, then it quit. After that, you could push the cold start button and it will run for about two minutes, then slowly die. First, I rebuilt the lift pump, no change. Then I found a small fuel leak in the line at the inlet to the lift pump, so I replaced the line thinking it was sucking air. That didn't change anything either. Note, the fuel tank is clean, and the fuel is fresh and clean.
Here is a description of what it does. Crank the tractor, it runs fine for about two minutes, then slowly dies. After it dies, you can bleed the fuel system, and air comes out each bleed screw. (I'm bleeding the screw on top of the filter first, then the rear screw on the injector pump, then the front screw) Then you can crank it and again it dies after two minutes. Now, while it's running, no fuel is returning back to the tank, but when you use the manual pump lever on the lift pump, the fuel will return to the tank. Also, when it is running, it runs fine, doesn't miss, smoke or anything. It cranks right up without using the cold start right after it's bled.
I did find one small leak where the line comes from the shut-off valve on the tank to the lift pump. It appears that the threads on the shutoff valve are damaged. I'm going to replace the shut-off valve to fix the leak.
Is it possible that there is enough air coming from the leaky fuel line to kill the motor? I know it has leaked in the past, and it ran fine. If there was a leak somewhere that was sucking air, fuel wouldn't come out, would it? How would I find a leak like that? What could cause the fuel not to return to the tank when it's running?
This thing has me baffled. I don't know what else to try.
That screen is missing. The new valve should come with one.
/ 1973 Ford 5000 Will Not Run #6
I take it the tractor does't have a fuel filter? And also, you say it runs for 2 minutes, is that Idle or full throttle?
Either way, it sounds like poor fuel flow. Maybe have pump checked if all else fails. Without a filter, gunk could have entered and partially plugged fuel pump.
It has a fuel filter, a brand new one. It doesn't matter if its at idle or full throttle.
/ 1973 Ford 5000 Will Not Run #8
Bypass screen, filter. Fill up an clean 5 liter buchet with new diesel. Put the feedline directly in the bucket. Bleed the system from "buchet to top", meaning do not forget the 4 diesel injectors C9NN9F593B. This way we got a lot of Volvos, Scanias did not stop ;-), running when frost clogged the fuel lines during the winter months. If it works on a 6 cyl. Volvo,
it works on a 4 cyl. Ford.
/ 1973 Ford 5000 Will Not Run #9
Our old 5000 did this a while a go and the lift pump on the side of the motor had a fine crack in the seal within the lift pump, a new lift pump and away it went. Pumps aren't all that dear just be sure to get it back on the crank shaft correctly.
/ 1973 Ford 5000 Will Not Run #10
ensure good flow that does not taper from the tank.. pull return line and aim into bucket.. bleed out and see what you get.
post back
Thanks for everyone's replies. I got it running yesterday. I checked all the lines for leaks (again), still nothing. So I started all over. I pulled the line from the filter to the inj. pump to check for flow. It was flowing good using the hand primer, so I checked it while turning the engine over. No flow when turning the engine over. Apparently after I re-built the lift pump, the pickup lever was on top of the cam in the inj. pump..... I took the lift pump off, re-installed it and it's good to go. I've still got to replace one line and I'm going to replace the drain cock, but at least it's running now.
/ 1973 Ford 5000 Will Not Run #12
I would take the return line off the head and blow back to tank to make sure line is clear. on fuel line sucking air, We usually never see a fuel leak when we have air in the fuel, Usually when we see air in the fuel the unit will smoke and carry on with low power/rpm. Not sure but does the injection pump have a inline screen before it goes to lift pump or injection pump.
2018 CATERPILLAR 326FL EXCAVATOR (A65053)
2018 CATERPILLAR...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
2001 John Deere 6210 (A60462)
2001 John Deere...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
Ford Tractor (A62613)
