Harvesting Black Walnut with an Alaskan Saw Mill
/ Harvesting Black Walnut with an Alaskan Saw Mill #1
LogChain
Member
Oak Ridge, Tennessee
None
Well, it finally happened. A gust of wind on the leading edge of a thunder storm took down one of my black walnut trees--one that had been ailing for several years. The tree had stood ~70 feet tall, was ~18" in diameter at its base, and was located ~100 yards from the house in a wooded area difficult to reach except by foot. Because of its size and location, it was not a good candidate for the local portable saw mill operator, but was of great interest to me as a hobbyist woodworker. Sadly, I am way overdue in making my youngest daughter her dresser :eek:. So with a nudge from Mother Nature, let the fun begin :licking:!
I've been following MotorSeven's "The Log house Project begins ........" thread http://www.tractorbynet.com/forums/projects/156451-log-house-project-begins-32.html for several years and have especially enjoyed seeing what he has done with his portable saw mill (e.g, ~ Post 315). I thought I might share with interested TBN members a smaller scale project using a smaller scale saw mill--the Granberg 36" Alaskan Saw Mill. I hope to show the steps to harvest successfully black walnut lumber from a single isolated tree.
The Alaskan Saw Mill is a rectangular frame that clamps to the bar of a chain saw. I use a Husqvarna 3120 XP power head with a 32" bar and a rip chain. The saw has plenty of power (8.4 hp) and a trigger lock--two features which are important for portable saw mill use.
I also use the Alaskan Saw Mill G 850 slabbing rail brackets for the first cut of a log. Instead of using 2 x 4's for rails as suggested in the instructions, I use a pair of 10' perforated steel UniStrut channels. They seem to be straighter and stiffer than 2 x 4's and don't tend to get cut up for other purposes and be unavailable when needed for slabbing.
Before slab cutting (or live sawing) the logs, I limbed the tree and cut the top and branches in 22" lengths for firewood. Other trees that were in the fall line of the walnut were also cut into fire wood. My "orange tractor" (the 5.5 hp DR Power Wagon--it's all I've got :eek:) was convenient to bring the fire wood up the hill to the house for splitting. I may be one of only a few TBN members whose chain saw can out power his/her tractor.
Next, two logs 9' 6" long were cut from the trunk, and the lower log was pulled into a convenient position for slabbing with my log winch/skidder (human powered at about 0.25 hp :sweatdrop:). Although this setup lacks a LogChain (my moniker), it's light and effective.
Then the two rail brackets were leveled and attached at opposite ends of the log equidistant from the log center (in this case ~6.5") with four duplex-head 20p nails. The two 10' UniStrut rails were finally placed on the brackets roughly parallel to each other and secured with nuts.
After setting the rails, the day was getting late, and I was getting tired so I decided to delay slabbing until this coming weekend. Yes, I've got a job. Please stay tuned :rolleyes:.
-- LogChain
/ Harvesting Black Walnut with an Alaskan Saw Mill #2
Subscribed! Watching with interest, as I have a big stand of black walnut trees and a house to help build over the next few years. I'd love to mill some slabs for counters, cabinets, trim, furniture, etc. A full-on sawmill is out of my price range for the foreseeable future, but an alaskan mill might be doable. hate to put that kind of hurt on the chainsaw, but maybe it's not so bad...?
/ Harvesting Black Walnut with an Alaskan Saw Mill #3
Interesting. I always wanted to try one of those things.
/ Harvesting Black Walnut with an Alaskan Saw Mill #4
Cool! I look forward to seeing the rest. I have two walnut logs I want to get sawed up at some point. Have been thinking about getting an Alaskan sawmill rig.
deezler, if you have a big enough saw (at least 70cc) and the proper bar/chain, it's not bad at all. For sawing boards, you can get a narrow kerf rip chain with cutters designed specially for this task. When cutting along the grain, the ripping chain will not slow down or heat up like a regular chain would, plus it clears chips better and makes a much smoother cut. Just don't free-hand or cross-cut with it -- it's definitely intended to be used in a jig.
Thanks for expressing your interests. I find two websites particularly useful for information on the Alaskan Saw Mill and lumber harvesting in general:
Welcome To Madsen's Online
and
Husqvarna Chainsaws, Outdoor Power Equipment and Tree Care Supplies from Bailey's
They have some good tips, pictures, and what I consider sales videos on using the Alaskan Saw Mill. They also discuss (and sell) several types of rip chains.
I now use the Oregon #72RD rip chain I got from Madsen's. It looks (and costs) similar to a standard saw chain but the top plate has a little blunter angle which makes it a little more aggressive. I have, by mistake (or perhaps by laziness), used the Oregon rip chain for cross cutting. It crosscuts noticeably faster than the standard saw chain but should probably be used only for ripping for safety (kickback) reasons.
I have used other rip chains with a skip-tooth type designs that work well also. See for example:
Granberg Ripping Chain | Granberg International
As I recall, however, these chains were a little harder to sharpen than the Oregon rip chain. Whatever kind you use, be sure that the pitch is right for your sprocket and the gauge is right for your bar. I have a few mismatched chains in my closet.:duh:
My chain is sharp, my powerhead is fueled and oiled, and I'm ready to RIP (Saturday)! :thumbsup:
-- LogChain
/ Harvesting Black Walnut with an Alaskan Saw Mill #6
I love the internet. I'm just biding time til I retire and can start doing stuff!
/ Harvesting Black Walnut with an Alaskan Saw Mill #7
Using a sawmill is a lot of work. I use mine every now and then. Here are some slabs I made benches out of. That is some nice looking black walnut he is sawing...
Stick,
My view on this is, "Do as much 'stuff' as you can now before you retire so when you retire you're in good enough shape to do 'stuff' full time." :) What you do now is training for retirement.
-- LogChain
/ Harvesting Black Walnut with an Alaskan Saw Mill #9
Have you considered using screws instead of nails to hold the rails.:D
Just for information I've made my own chainsaw mill. There are pictures of it on TBN.
/ Harvesting Black Walnut with an Alaskan Saw Mill #10
A beautiful tree. Looking forward to more pics of your project.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Mini John Deere Truck (A55853)
Mini John Deere...
1988 FRUEHAUF TRAILER OPERATION FUEL TRAILER (A60736)
1988 FRUEHAUF...
Giyi PG72 QA 72" Grapple (A60463)
Giyi PG72 QA 72"...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A60352)
2019 Allmand...
