I need a step for a B7610
/ I need a step for a B7610 #1
Timber
East Bridgewater Massachusetts
Kubota B7800
My dad bought a B7610 and has a little trouble getting on and off his tractor. I can make a step for it and it's looking like I'm going to have to. I was just wondering if their is a factory step made for the Kubota B7610 that he can just order
/ I need a step for a B7610 #3
I don't believe there is an factory step, but how about ordering a step for n L3400 or L3800 and putting it on?
James K0UA
Yea I herd the L series step can be made to work, I might just be easyer to just make one, I'll have to check but I think I can use my B7800 as a model
/ I need a step for a B7610 #5
This on my B7800, maybe this can help. It was real easy to make.
/ I need a step for a B7610 #6
You might watch him get on and see if additional grab handles/bars would also help in addition to the extra step. See how far he has to reach to grab something now
( the edge of the dash, the steering wheel, etc ) to help pull himself up, as well as climb down safely.
/ I need a step for a B7610 #8
Timber said:
Ok this is what I came up with
That's really slick! Are you planning to add anti-slip tape for traction? Again, nice work.
If my dad wants that he can add it, I'm going to make one for my B7800 and I will not bother with that for mine. It sure has made a world of difference for him. He broke his back on his Dynahoe 10 years ago and he has a hard time with his legs
There is another thread on this in the build it yourself forum. I just wanted to compleat this thread for future searches
http://www.tractorbynet.com/forums/build-yourself/258009-step-my-dads-7610-kubota.html
/ I need a step for a B7610 #10
Wow that is really thinking out of the box.. Looks good.
James K0UA
Thank you, I wanted to build a foot step for a B series tractor that wouldn't effect the ground clearence for this size tractor. It has made a huge diference for him.
/ I need a step for a B7610 #12
Ten years ago I bought a B7800, and found that it was a bit tiring getting on and off the thing. So I bought a ready-made Kubota left-side step (I forget what model tractor it was intended for) and installed it on the B7800. Made it much easier for this "senior" to use the machine safely and comfortably. One thing I had to allow for was sufficient clearance for the mid-mount mower that I use frequently on my property. If the step hangs too low, it will prevent the mower from rising properly.
HOLLAND 4R FINGER TYPE SETTER (A63291)
HOLLAND 4R FINGER...
2020 BOBCAT E42 MINI EXCAVATOR (A63569)
2020 BOBCAT E42...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
2017 FORD F-250(INOPERABLE) (A63569)
2017 FORD...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2006 Mack CV713 Flatbed Truck (A62679)
2006 Mack CV713...
