DIY mudjacking
/ DIY mudjacking #1
rmankty
1948 farmall cub
Hello,anyone do any mudjacking or use a manual grout pump before? I am seeking any advice for equip etc for filling voids near pole barn shed under driveway.I have already priced grout pumps from kenrich and wastecorp,and hoses from these co.s and others,but I havent purchased any equip yet.Im talking about undoing woodchuck works.Thanks for any advice!
/ DIY mudjacking #2
When I was still working for the DOT, we hired a guy with a small towable grout pump to fill some small coal mine shafts under a couple of roads. May consider that, instead of buying one.
I have a neighbor that made their own mudjack, to seal up around their springhouse. A large bore hyd. cylinder, hooked to a smaller cylinder the same stroke. The large bore was the pump, and the small bore provided the pressure to push. Just need to figure out the plumbing, and valves to load, and disperse...
What I've worked with, just make sure you have a screen, to screen out the lumps. Guarantee there will be some in a ready-mix truck. Not much fun dragging a full 2" hose full of grout out of a hole..!! Let alone tapping the hose with a sledge, to mash up the lumps...
Not sure where you are located, but we always had them add fly ash from coal fired power plants to the mix. Makes it flow a lot better..!!
/ DIY mudjacking
Thank you very much for excellent information! I have priced new grout pumps from wastecorp and kenrich, a new hose couplings run about $1000.I will see who I can find to have it done,although over time having my own equip can come in handy.I live north of Ohio.Thanks again for your help!
/ DIY mudjacking #4
Maybe even something like around here they call "B-Level", leveling company. I believe it is a franchise type deal. But maybe look under sidewalk leveling. Just a mudjack, to level sidewalks, slabs or whatever.... Probably truck/trailer mounted, so they could get in anywhere.
/ DIY mudjacking #5
If you are filling voids beneath concrete structures, consider using bentonite in the grout. It will help to prevent shrinkage and avoid as many air gaps beneath the structure as possible.
/ DIY mudjacking
Thanks alot for the good advice!
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
CrustBuster 3800 Drill (A66285)
CrustBuster 3800...
2021 Topcat SSSTG200 Stump Grinder (A62679)
2021 Topcat...
John Deere 33 Manure Spreader (A66408)
John Deere 33...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
