Chains Chains for my 3320
   / Chains for my 3320
never.......
   / Chains for my 3320 #12
I'd say go for it if you have no pavement to tear up. Make sure to get the chain tensioners.
My 4310 is the predecessor to the 3320 so I think you can get an extra inch or better clearance by flipping the rears. Just enough room on mine. Are you going to do all 4 wheels?
   / Chains for my 3320 #13
never.......
Then if you want the ultimate in ice traction go for the 4-link V-bars.
I faced a similar decision a few weeks ago when I bought the chains for my new 2720. I had V-bars on my NAA and only ran on gravel but now with the 2720 and the blower I may need to run on some pavement so I chose to go with 2-link ladder chains.
I agree with the other poster about getting the tensioners.
I have already flipped the rears so I should have plenty of room. I do not plan on the front as I have read some posts that refer to that as a bad idea. My sense is that it may lock everything together too much. ( Not trying to start a 4 wheel chain debate).
   / Chains for my 3320 #15
Yeah. No need for that. I read a lot of threads on the subject. I decided I needed all 4. No problems yet but they don't have that much time on. I will tell you that I took it everywhere and beyond where my 790 got stuck. It was a pretty great feeling to go straight into a drifted over ditch, stop and reverse right out. I know they are 2 different tractors but the same size and brand of tires.
   / Chains for my 3320 #18
I have the larger tires on my 3320. I opted for the 2 link chains from TireChains.com as I do drive on pavement sometimes. If you're not going to drive on pavement the 4 links might be ok, one thing, they are lighter and will probably go on and off quicker. I use the stabilizers from my 485 hoe to put them on and take them off, by the way.
   / Chains for my 3320 #19
Those aren't chains... that's a weapon!
   / Chains for my 3320 #20
I strongly recommend Canadian Chains in Showhegan...been buying chains from them since the 70's
Canadian Chains [Home]3320 chain rear.jpg Here are the chains I got from them for my 3320...they will make sure they will fit any type of tire.
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2020 DRAGON ESP...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
2019 Ford F-550 ETI ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
