Buying Advice Skid steer -vs- Compact Tractor
   / Skid steer -vs- Compact Tractor #1
freddymac63
I'm a tractor novice looking for advice on the best suited machine for my application, skid steer or compact tractor. I have a fair sized timber tract that requires the following work:
  • clearing property lines of timber & brush. Dirt work required for fencing
  • Install fence
  • mowing firebreaks
  • improving old pond, constructing new pond
  • improving roads, installing ditches and water bars
  • piling up timber slash
I estimate it will take me 50 years to accomplish all this so I need something that will last also!
   / Skid steer -vs- Compact Tractor #2
Skid steers are cool, fun and expensive much more than a compact! I like a compact others will disagree!
   / Skid steer -vs- Compact Tractor #3
I would go with the compact. More tools to work with and get the job done, and cost lest.
   / Skid steer -vs- Compact Tractor #4
  • Install fence
  • mowing firebreaks
I am in the same boat you are in...same property issues at hand, and no...I'm not done yet either, but here is my advice, and what I did....Get a compact with a backhoe. Its probably the best choice I've made. A neighbor of mine (with adjoining property) has a bobcat skid steer and he has let me use it for some of the pond work, and clearing. Although its much faster and more agile than a compact, when it comes to digging ditches and working the road a compact tractor and back hoe cant be beat. I ended up buying myself a Kubota L3200 with backhoe for around 28,000 with a trailer included. A bobcat skid steer was more than that and didnt have the clearance (undercarriage) to go off roading like i needed to do. I LOVE my tractor and its done an excellent job on my property so far (116 hours***bought it brand new). Just my opinion...you'll be happier and be able to go more places in the woods /property with a compact.
:thumbsup:
   / Skid steer -vs- Compact Tractor #5
attachments for skid steer are very expensive.
   / Skid steer -vs- Compact Tractor #6
Skid steers are made to PUSH. If you want to power a skid steer implement it is in front 99% of the time and the implement is always powered off the skid steer hydraulic system. (Know anything about hydraulic systems?) No choice in tire sizes, very little in tire types. Rough on the operator due to short wheel base, small wheels and hard tires; tracks WORSE.
Tractors are made to PULL. Quite a few applications use the tractor to PUSH, of which the most common is the FEL/bucket. Tractors are never quite as satisfactory pushing as they are pulling but they do both. Implements are powered off the PTO, which is part of the tractor already, SIMPLE, RELIABLE and efficient at power transfer. If you are working dirt, with an implement carried in the 3 point hitch, the dust is behind you. Wide assortment of tires types and sizes available. Tractors are more comfortable for the operator.
I suggest you browse the implement videos at everthingattachments. com:
EverythingAttachments.com
Good luck on your choice.
[ you want a tractor/loader ]
   / Skid steer -vs- Compact Tractor #7
Compact tractor. Rent a bobcat when you need one. :thumbsup:
   / Skid steer -vs- Compact Tractor #8
It's not a matter of which is the better machine both are made for a job. I have owned/own both and from what you describe you'll be better of with a compact tractor unless you want to upgrade to a tracked SS. Not sure what your $$$ are but SS's are more expensive then compact tractors. If it where me I'd buy a compact with small dump trailer and a used mini excavator, you'd be surprised what you could do.
   / Skid steer -vs- Compact Tractor #9
I have access to skid steer, backhoe and track hoe but I love my enclosed tractor w/ loader that cost less than half of a enclosed skid steer.
   / Skid steer -vs- Compact Tractor #10
I agree with others here, get a tractor. A much more versitile tool IMO. Skidloaders excell in everyway at dirt and loader work. But thats where it stops.
The things I see on your list that would be better with a SS but not impossible with the tractor are dirtwork, fencing, and piling timber. But that you would want a skidloader, post hole digger, and a grapple bucket at the minimum. And if pricing new, you are looking at pushing $40k
The tractor would be better for the driveway maintenance and PULLING logs wherever you want, and mowing. But it can still dig postholes (cheaper attachment too), and can still use the loader for piling logs and doing dirtwork, just a bit slower though.
I am not sure what size timbers you are dealing with or the size of your property and ponds. There is a HUGE difference between 5 acres and 100 acres in terms of what SIZE machine to get. But for the money (and even considering a SS in the mix) I would opt for something in the 30-40HP range if you are in the ~10acre range and WITH a backhoe.
That backhoe would be VERY handy when doing your ditching work, stumps, and general pond maintenance. A tractor with loader and backhoe (TLB) will do way more than a SS can do. Sure, you could get a backhoe for a SS, but it just isnt the same as a true backhoe.
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
David White LT6-900 Level Transit, S/N C500926, Model 8834 (A59076)
David White...
Mini Skid-Steer Land Leveler (New/Unused) (A59225)
Mini Skid-Steer...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A58018)
2018 VOLVO VNL...
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
