EverythingAttachments NEW Rear Scrape Blade
   / EverythingAttachments NEW Rear Scrape Blade #1
Elite Member
Newton NC
Which One do you want to know about?
I was just down in our shop and noticed our new EverythingAttachments Xtreme Duty scrape blade is painted and ready for the photo booth and the video shoot.
Look for it, complete with prices, on our website soon. See the "sneak peek" below!!
Made from 3/8" American steel right here in Newton, NC and weighing in at 465 pounds(for 7' Blade). We have made the ultimate scrape blade complete with tilt, angle and offset features to ensure it can do any job you need it to. Also available with side walls and rounded skid shoes to make it even more versatile. This scrape blade should be available for sale within a couple weeks.
   / EverythingAttachments NEW Rear Scrape Blade #2
That looks like quite a piece :thumbsup:
   / EverythingAttachments NEW Rear Scrape Blade #3
why not include attachment points for a side shift cylinder as optional equipment?
   / EverythingAttachments NEW Rear Scrape Blade #4
That's a great looking blade, I like it.
   / EverythingAttachments NEW Rear Scrape Blade #5
I'm not seeing how it tilts.?
   / EverythingAttachments NEW Rear Scrape Blade #6
I think its in that backing plate. I dont think you can see the holes where it locks in though. But I could be wrong.
Does look like a decient blade though. 3/8" steel....:thumbsup:
I wonder if they got any HP ratings for it.
465# is pretty hefty. But I still like a MUCH heavier blade simply for ballast purposes.
   / EverythingAttachments NEW Rear Scrape Blade #7
First thing I thought when I looked at the pics too.
Nice blade in any event.
   / EverythingAttachments NEW Rear Scrape Blade #8
Go Ted! Go Peanut! Go Everythingattachments.com!
Thanks for your comments guys and we appreciate all of your support!
It is always exciting for me to unveil a new product from our facility and I'll try to announce my new attachments to the TractorByNet community first in the future. I don't try to make our attachments as good as the highest priced equipment out there, I make our attachments BETTER! I cannot say that enough and we plan to build our name even more by continuing to offer you quality USA made attachments, great prices and outstanding customer service.
I'll answer some of your questions:
This blade will be rated for 30-80hp. 30 is pretty low but will be fine on older 30hp tractors and large framed newer CUTs. I will be making a lighter blade for smaller tractors hopefully in the near future.
At this time, I do not have plans for cylinder brackets but that is an idea that we will consider for the future.
The blade has 5 tilt settings on the rear backing plate like LD1 said. It also has 7 forward and 7 reverse settings AND 7 offset settings.
It is also quick hitch and I-match compatible.
   / EverythingAttachments NEW Rear Scrape Blade #10
Any plans on making a heavier yet blade but still on smaller 6' sizes?? Something in the 650-700lb range??
I would really love to have a KK HD 6' blade. But for now, I make due with my 7' 700lb model. I like the weight:thumbsup: But 7' is a bit much to get agressive with it. As I have said before, dirt work and loader work go hand in hand. And most blades on the market just arent heavy enough for loader work. I would want no less than the 700lb I have. A 650-700lb 6' blade would be about perfect for most 30-40HP CUT's IMO:thumbsup: Just some food for thought.
I wanted to target the most popular size/weight/hp range for our first blade so it kinda hits the "sweet spot" for many applications and tractor sizes. I think our next blade will be a lighter blade in the 300 pound range for small/mid compacts and subs but may eventually make a blade in that 700 pound range. I wouldn't hesitate to put this blade behind a tractor and get aggressive with it because everything is designed to withstand abuse but it still doesn't help your counterweight needs.
   / EverythingAttachments NEW Rear Scrape Blade #12
Yea, at 3/8" thick, and seeing how it is built, no doubt that it will take some abuse. The counter weight thing is my biggest issue. Sure, a blade can be made pleanty strong for any tractor, yet still be 2x's too light for effective counterweight.
How about a 700 pound box blade? :)
   / EverythingAttachments NEW Rear Scrape Blade #15
View attachment 280223View attachment 280224View attachment 280225
Greetings
Can you please tell me how tall is the moldboard on this blade? I'm looking for around 18"s. Thanks
   / EverythingAttachments NEW Rear Scrape Blade #16
Ted,
Would just the blade work on the EverythingAttachments landscape rake's 3-point hitch frame? I just bought the 5' landscape rake and wondered if - when you make the smaller blade - it could use the landscape rake's 3-point hitch frame.
Greetings
Arrow,
It measures 16 1/4".
Thanks
Ted,
I do not have the smaller blade totally designed yet so I don't have a good answer to your question. Hopefully, we will have that one out in the next month or two so I can let you know then.
Thanks for the questions guys!
   / EverythingAttachments NEW Rear Scrape Blade #19
That is one really nice and heavy-built blade, EXCEPT, I believe you will find significant force and wear aroung the 4 bolts attacking the frame/carrier to the blade. Both my Freeman and my old International Commercial HD blades are constructed almost identical (even down to the way the International swings/offsets) and I cannot keep those bolts tight. In addition, both blades have developed a slight bend to either side of the attaching points. As a result, on the Freeman blade I rebuilt the top attachment to include about 2 feet of angle, welded to the carrier and bolted to the blade and rebuilt the bottom with about 4 feet of angle, again welded to the carrier and bolted to the blade. Have to do the International soon! You have included so many heavy-duty aspects to this new design, unfortuneately, I think time will show the blade connection as the weak link.
At Everything Attachments we used the basic design with a lot of improvements in strength and options from a blade we have been selling for over 40 years. The pictures shown are the Rhino 500 series, with a dealer cost of over $1,400, without it being quick attach ready, which they offer a kit for an additional $350. If you notice we have added an extra plate with braces around the kingpin, where the rear blade adjusts and the 4 bolts you are speaking of, if kept tight, should not be a wearing issue. The reason it is bolted is because there are holes to the left and right for extra offset if needed. We are rating this blade from 30 to 85 horsepower. The only thing i can think of having a wear issue there would be if the bolts are a low grade and stretch which would let them become loose and wear but I have never seen one wear there
Ted Corriher
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2019 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2019 CATERPILLAR...
FUTURE 60" PALLET FORK (A60432)
FUTURE 60" PALLET...
Takeuchi TB016 (A53317)
Takeuchi TB016...
Attention (A57148)
Attention (A57148)
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
