What is JD's answer to the B2620?
/ What is JD's answer to the B2620? #1
ohbehave
Knoxville, tn
Kubota L3200 (2012)
I like the basic size of the B series.... good for my pupose, I think, of crawling around in my woods and clearing things. The tire size looks right and the ground clearance, too.
The B2620 look like an economical option.
The John Deere dealer is very, very convenient to me....and would rather have a nearby dealer. Online, I'm not quite finding anything that compares, but it's a clumsy web site. The smaller JD tractors have wheels that are far too tiny up front.
/ What is JD's answer to the B2620? #2
You might want to post this on the JD site. In my opinion there is no comparison to the Kubota!
/ What is JD's answer to the B2620? #3
Not sure which JD models compare, but;
My Kubota dealer is one hour away, and worth the drive.
My John Deere dealer is 5 minutes away. The Kubota is 30 minutes.
Regardless, surely there will be someone here who knows... roughly ... the kinds of JD tractors that are designed to compete at the level of the B-standard series.
Thanks for the quick responses, though... very cool!
/ What is JD's answer to the B2620? #5
The JD 2520 would be comparable. I think you'll find a few more deluxe features on the JD, including position control versus Kubota's quarter inching. In my area, the John Deeres are substantially more money than the comparable Kubota. Both excellent tractors, so check out both brands and see which has the features you want and 'fits' you better.
Beware of the color blind people of all brands. Might even want to look at several other brands in your area.... you might be surprised at what you find.
/ What is JD's answer to the B2620? #6
The local Deere dealer is 5 minutes from my place, and I have given them business in the past, but my recent purchase was a Kubota B2920 from a dealer 50 minutes away. I just liked the price and features of the Kubota better.
The counterpart to the Kubota B2320/2620/2920 would be the Deere 2320, 2520, 2720. They are very good tractors, and have 2-3 features that are better than the Kubotas (like position control). But the Kubota has some compelling features too, like the three-range transmission and more metal in the bodywork. Check them all out, consider price/value, and see which one you like best. You honestly can't go wrong either way.
From what I can tell, the front wheels on the Kubota B has taller front wheels. The John Deere site will let your "build your own" 2520, but can't find any info or brochure type stuff on it.
It does appear to be priced a little high.... closer to the B2630 rather than the B2620.
/ What is JD's answer to the B2620? #8
The budget minded Kubota 2620 doesn't have a direct JD comparison, in my mind. The JD 2520 is a deluxe tractor and matches up better with Kubota's 30 series B.
/ What is JD's answer to the B2620? #9
Here is a link to a brochure. JD's website is clumsy at best. It used to be an easy to use site. JD dealers tend to discount quite a bit off list, so you may want to get a quote from a couple of dealers.
2000 Tractors Series - Product Catalog
/ What is JD's answer to the B2620? #10
When I was looking at Kubota L3200-3800 models, I did look at the JD equivalent. The JD was smaller, had shorter tires, less ground clearance, had plastic hood and fenders, loader did not remove as quick and easy as Kubota and the cockpit was smaller.
I went with the L3800 and could not be happier.
Best advise I can give, is to go look at both green and orange in person and pick the one you like best.
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
Schulte SBW800 Rock Windrower (A61307)
Schulte SBW800...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2017 Nissan Altima 4 door (A61307)
2017 Nissan Altima...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
1996 CATERPILLAR D6E CRAWLER DOZER (A62129)
1996 CATERPILLAR...
